combi boiler help.....
[Closed] combi boiler help..... please!
5 Users
hi out there,
i have a Bosch Worcester greenstar combi boiler I have a couple of problems with:
When I run the hot tap in the bathroom the boiler works fine for 3 -4 mins then trips out, restart and repeat. It only does this with this ONE hot tap in the house.
Recently when having a shower the hot water has become very twitchy ie it's either scalding hot or freezing cold, all within about 5 mm rotation of the shower mixer.
both faults are in the bathroom which is at the same level as the boiler. Don't know if that makes a difference but thought it might be relevant.
any thoughts anyone? (preferably folk with some plumbing heating knowledge!)
cheers
Khayamolly.
Posted : 28/08/2013 5:17 pm
The shower symptoms suggest the mixer may be faulty. I had a faulty shower mixer that allowed cross-flow between hot and cold, even when in the off position, so as soon as I turn off the hot tap, cold water backfed into the boiler. Don't immediately see how that could cause your boiler symptoms but worth checking out - once your system is not working as designed lots of weird things can happen! Fixed by putting non-return valves in the the pipes to the shower (replacing the shower will be done sometime but is a big job as the pipes in the wall are non-standard).
Posted : 28/08/2013 5:37 pm
Rift in time-space continuam
Posted : 28/08/2013 5:56 pm
not sure how it trips out on the hot tap as the temperature is controlled to 58 ish degrees iirc from mine.
I suspect the two are separate faults and mixer sounds like a good one.
Posted : 28/08/2013 6:01 pm
Could be a faulty flow rate sensor . Lowish flow = very hot water , sensor then tells boiler tap/shower is off ( when it isnt ) and turns off heat. Water still runs but goes cold.
See if you can recreate this by popping the cover and running a hot tap in the bathroom.
The boiler will fire , and you will see flames, get your assistant to slowly turn down the flow rate. Shout when flames go out , if tap is still running then you have a problem somewhere.
Posted : 28/08/2013 7:10 pm
thanks all single track mind sounds the mot likely as the shower is only a year old. However I am inclined to agree with dales rider and blame a rift in the space time continuum.
thanks all will investigate
Khayamolly
Posted : 29/08/2013 10:19 am
