Chainsaw advice
[Closed] Chainsaw advice
There are some conifers at the end of the garden that need taming. They are about 4m high and 5m wide, 1.5m deep.
Basically I want to take 1.5-2m off the top with the minimum amount of effort
Any advice welcome
Posted : 18/10/2011 3:20 pm
If you can get a power source there and you really don't think you'll be doing too much chainsawing in the future, B&Q do a decent electric one for £50. I've cut logs about 40cm in diameter with no bother.
Don't forget safety gear, mind you.
Posted : 18/10/2011 3:24 pm
Up you go.
Posted : 18/10/2011 3:26 pm
£50 you say for an electric chainsaw? Tempting.
Thanks!
Posted : 18/10/2011 3:28 pm
When you're up in the tree just make sure you have secure footing. Where are you located?
Posted : 18/10/2011 3:30 pm
handsaw should be able to take the tops off - chainsaws especially when working at heights are dangerous toys - as well as the saw yo need the protective kit
Posted : 18/10/2011 3:33 pm
Just bear in mind that where you top the conifer, it will regrow in a pair of branches reaching for the sky.. double the trouble later if ignored to long.
A decent handsaw like a Silky Gomtaro will make short work of them, as conifers aren't ard!
http://www.silkyfox.co.uk/sheathed/gomtaro.html
[url= http://farm7.static.flickr.com/6020/5976905137_9fcaf902f4_z.jp g" target="_blank">http://farm7.static.flickr.com/6020/5976905137_9fcaf902f4_z.jp g"/> [/img][/url]
(thats my old saw, the Gomtaro is much better)
Posted : 18/10/2011 3:53 pm
+1000 for a SILKY, Ive got 2 now, a Gomtaro 270 and a BIG BOY!!!
Posted : 18/10/2011 4:05 pm
 ski
If they are 4m high & you want to take 2m off then a handsaw and tiptoes is all you need.
Also worth checking out the Bahco 396 Lap Laplander, which are a little cheaper than the Gomtaro.
Rocketman, where are you based?
If its local to me, I will do it for the wood, you will have to burn the brash mind 😉
Posted : 18/10/2011 4:14 pm
As said for a small hedge by hand works well as they are quite soft...I have a tall leylandi connifer hedge in my garden...The back hedge is about 5m high and acts as a screen. I have just had to climb up and do the pruning last week. I cut the top of it with a Stihl HT 75 pole chainsaw attachment... the great thing about this tool is that it takes a hedge cutter swell as a chainsaw so is a great all round garden tool. The hedge is very deep swell as high so the pole attachment is superb. I think you can also buy a strimmer attachment for it. The new model it HT 100 I believe. I find myself using the pole chainsaw more than the regular one. Downside is the cost about 650!!! not inc both attachments!! I have regularly cut the connifers over the last few years so its now a good dense hedge. Biggest hassle with my pruning is clearing up the waste.
Posted : 18/10/2011 6:40 pm
Im generally regarded as having a cavalier attitude to chainsaw safety, but I'd advise against cutting anything over chest high with both feet on the ground.
Posted : 18/10/2011 7:45 pm
