We have been in current house from new, 13 yrs ago. Its a modern detached with a cheapo gas central heating system (non combi). It has microbore ? small diameter piping. Over last few years, in common with many neighbours, it has got noisy with cold spots on rads. We had a chemical flush last year while replacing a few radiators in kitchen when refitting it, which helped a bit. That plumber advised against a power flush on basis that it could make leaks at pipe joins.
Quite a few neighbours have though had theirs powerflushed with great results, by British Gas, no leaks and a guarantee. Not cheap at £600 but seriously considering it if it rejuvenates the system.
Any advice from those with experience ?
I thought Id booked a powerflush last year
The guy turned up, fitted a humungous temporary filter to my system, added some chemical goodness and returned a few days later with a bloody big mechanical bashing type thing which he then used to knock seven shades of **** out of all of our rads
After he finished he took out his industrial filter and fitted a permanent one which Id asked for
The stuff his filter collected was pretty impressive
My central heating is massively better although it is an old system
I had it power flushed 10 years ago and did have the concerns you mention about blowing seals and pipe joints
Im very happy with the bashy type way of doing it but dont know if its official or not, however with a 30y old system Im happy to avoid the stress of blowing it up with too much pressure
I paid 500 notes all in including having my own filter fitted
Interesting, will research a bit more, cheers
If you are having flow issues, which is pointing to sediment / cold spots. A powerflush is the best way to clear it out. Just remember to keep the dosing of inhibitor going, as obviously there isn't enough in there, as the rads are rotting and silting the system up.
Google Magnacleanse (bashy technique),prepare for the usual internet conflicting reviews,I use this system as it does not increase the pressure of the system and you only need one dose of chemical.
