My cellar is reasonably clean and not too damp but the walls are a bit crumbly and flakey and the ceiling is exposed floor beams. whilst I would love to get it tanked and have 5* accomodation for my bikes I expect the cost rules that out.
Is there any half way house cheaper alternative, otherwise any suggestions for keeping the damp and dirt from the walls in check? What have others done to make the best of their cellars?
Rio
maybe buy a dehunidifier, i wouldnt cover the walls as i would rather be able to see the problem as opposed to cover it . maybe just put some plywood or mdf boards on the ceiling but make sure you can get easy access to pipes / electrics etc
Paint the walls with [url= http://www.decoratingdirect.co.uk/viewprod/z/ZINWT/ ]"damp proof paint?[/url]
I would be VERY wary of putting any damp proofing on the walls. That moisture is wicking up from the sub-soil. If it can't escape through the basement walls it will travel up to above the damp-proofing, ie into the above living accomodation.
Why not leave an old chain down there for a couple of weeks, if no rust forms it should be OK as is.
A
Worked for Mr. Fritzl....
thanks for the replies - I think I'll just board the ceiling for now and try leaving a chain down there to see what happens.
masonary paint on the walls (contains antifungal but shouldn't keep moisture in)
the 1m square/12mm thick rubber interlocking tiles you can buy from maplin on the floor stop damp coming up and are good for a workshop
a dehumidifier is almost essential
and don't leave stuff like in cardboard boxes against the walls
worked for me for a few years - will probably tank it one day but is a bit on the low side so never sure if worth doing meanwhile I slum it
How about a room within a room? Obviously depends on space but a wood frame with clear plastic sheeting should keep the moisture out while being a cheaper alternative to tanking? There would be an air gap of course to allow the walls space the breathe.
What is the difference between tanking it and using waterproof paint? If the waterproof pain might allow damp to go higher surely tanking it would as well
Tanking it allows the cellar structure to breathe - something it MUST do, stop it breathing and water WILL come in somewhere else/cause further damage
As I understand it, tanking the structure allows the walls to continue to let the moisture in, and then drain it away.
I don't fit cellars, but have fitted them out with luvverly home cinema kit, naturally needing a dry environment.
Jontawn
Your home cinema expertese may be able to help me with another question I posted
http://www.singletrackworld.com/forum/topic/any-tv-salesmen-on-here
Thanks
Rio
err - i'm not a TV salesman either ... *shakes head and coughs* ;o) haha!!
although just replied to you.
hope you get your cellar sorted out 😉
