Carbon capture proj...
[Closed] Carbon capture project cancelled
Any replacement window must be a replica of an original. there is no triple glazed unit that will fit in a replica window. there is only one manufacturer in the world that makes a double glazed unit that is compatible.
Which one of the nine named companies in this Historic Scotland document is the only one that is compatible? This is a serious question
[url= http://www.historic-scotland.gov.uk/slim-profile_double_glazing_2010.pdf ]Conservation Glazing www.conservationglazing.co.uk
Histoglass www.histoglass.co.uk
Pilkington energiKare Legacy www.pilkington.com/europe/uk+and+ireland/english/
energikareconsumer/energikare]range/legacy.htm
www.nsg]spacia.co.jp
Sashworks www.sashworks.co.uk
Slenderglaze www.sashconsultancy.co.uk
Slimlite www.slimliteglass.co.uk
Storm Secondary Glazing www.stormwindows.co.uk
Supalite www.peternobleglazing.com
[/url]
Posted : 23/10/2011 5:53 pm
TooTall - look at my posts at the top of the page, SeaGen is tidal not wave power.
Some developers have also been looking into the possibility of putting tidal turbines on the supporting structures of wind turbines in the areas with high tidal currents which is quite interesting but adds another level of complexity to things and I wonder if it will ever happen. The next ten years will be very exciting for marine renewables as the big developments are implemented.
What will be interesting to see is how many of the scottish ones survive the winter.
Its the source of much amusement for some of the boat operators in Orkney - I was up a few weeks ago and one of them reckoned Wello would break free first and then take out Pelamis and Oyster on the way to getting minced on the shore 😆 . I'm not sure if Wello will be out by winter though. I think Oyster faces a big challenge in survivability just from where and how it works, being a big flap in relatively shallow water, Pelamis needs to be in deeper water which is a safer place to be. I'd better watch my words though as one of the aquamarine guys is on here!
Posted : 23/10/2011 6:09 pm
Shutters on the inside TJ. They can't stop you doing that. Just as effective at cutting heat loss.
Yes, I own a 20-year-old car, or more precisely madame and I own a car and a van. The company you rent from owns lots of vehicles so one is avaiable for you when you use it TJ.
As you wish to compare greenhouse gasses emitted by our transport use I'll give you all the information you need. My wife and son use the vehicles more than me but I'll count all the fuel used as mine to make things simpler. I won't include kms in other people's vehicles I car share with as I save them at least as much fuel when they travel with me. You should include all the distance you cover in other people's vehicles, as you can't reciprocate.
Over the last 10 years:
0 air kms/year.
Up to 2000km by train per year but only about 1000 on average.
2500km by bus or coach per year for the last three years.
between 400 and 700 litres of motor vehicle fuel per year.
To help you: two people travelling to Australia and back in a 747 consume:
2 x 16983 x 2 x 0.03l = 8151 litres.
Posted : 23/10/2011 6:36 pm
I think they can, the conservation laws are quite strict and I think you'll find that internal shutters are not that good an idea due to potential problems of condensation, cracked glass and not as effective as external blinds for reducing solar heat gain either.
EDIT; There are generally no issues surrounding the installation or reinstatement of internal shutters, not a widely known fact.
[url= http://www.changeworks.org.uk/uploads/83096-EnergyHeritage_online1.pdf ]http://www.changeworks.org.uk/uploads/83096-EnergyHeritage_online1.pdf[/url]
Posted : 23/10/2011 6:48 pm
I'll agree with TJ on the Edinburgh planning regs being pretty strict, hence why at least half of the team in the council responsible for them being suspended over potential mis-management and fraud.
However, to go back on topic
Hide it in the ground and pretend it doesn't exist? need a better answer than that please
...was used as a complaint against nuclear, but surely doing the same with our CO2 is a bit hypocritical?!? Was I the only one to spot the irony in that statement?
Posted : 23/10/2011 7:07 pm
Thanks for checking and editing, Don. If anything internal shutters reduce condensation problems (which mainly concern the thermal bridge area around the window once the window is double glazed), cracking glass isn't a problem and even if not as good as external shutters for keep the dwelling ccol in summer they are better than nothing.
Posted : 23/10/2011 7:08 pm
Clearly the internal is better than nothing and I'm sure glass technology has moved on a bit since 1980 too. 😀
[url= http://www.nrc-cnrc.gc.ca/obj/irc/doc/pubs/bpn/17_e.pdf ]http://www.nrc-cnrc.gc.ca/obj/irc/doc/pubs/bpn/17_e.pdf[/url]
Posted : 23/10/2011 7:22 pm
I would have to apply for listed building consent to fit shutters which would be unlikely to be granted, as it is a listed building in a conservation area. Most of my windows could not have them fitted due to the construction of the window frame and surrounds as there would be nowhere for them to go or be fixed to.
You see guys - unlike you I know what my building is, I know what the regulations are and I know what is permissible and possible and I know what can be done and what cannot - And I have done everything I can practically do in most cases.
If you had asked me " can you do this" or "have you considered that" I could have told you - however you have kept trying to tell me I can do things that are not allowed or possible.
Tootall - pelarmis has been producing electricity on a commercial scale off the Portuguese coast for a few years now.
Posted : 23/10/2011 7:23 pm
Ottawa get somewhat colder than Edinburgh too, Don. 😉
Until you can produce a refused planning application for internal shutters we'll have to rely on general policy statements, TJ. And that says internal shutters are fine and even encouraged as they were original features that have been removed in many cases.
Until you can produce something to prove otherwise I assume that national policy applies and I can walk along your street, TJ.
You are inventing problems that don't exist. Your roof insulation must be lousy too if you have to heat. What's above your head, TJ? In my case there are 400mm of wood, rockwool and fibre glass. It was the first insulating I did. If I had to do it now I'd use a combination of recycled polyester, hemp, wood fibre or multi-layer stuff depending on space, the objective being R=7 or higher. You can get R=7 with three layers of 30mm multi-layer these days (100mm total).
Posted : 23/10/2011 7:39 pm
If you stop looking down on anyone with a differing view to you, or start answering the questions whn they are asked and generally treat people well....
The Changeworks document doesn't say anything regarding the prohibition of shutters, quite the reverse in fact. Neither does it say no triple glazing and according to you the double glazing isn't permitted either, clearly History Scotland have demonstrated that there is more than one supplier of slim double glazing, I get the feeling that someone is pulling your chain... I've told you how to deal with these people and you've done nothing but diss me and that attitude is probably why you have problems when you try taslking with these people. You're just not interested in listening.
Posted : 23/10/2011 7:44 pm
forum-big-hitter-bashing aside, to be fair to TJ, the diagram below of current consumption against a (massively optimistic) theoretical maximum UK 'green' energy production bar chart- crossed out indicatively after "public consultation" shows that home heating is only part of the massive amount of carbon produced by our energy consumpttion.....
there's obviously the argument as to whether nuclear is green or not.
all more clearly set out and debated from all aspects in this book (downloadable in full free) [url= http://www.withouthotair.com/Contents.html ]without hot air[/url]
apologies if the above book has been discussed and rubbished by more intelligent forumites.
just a soundbite from the above that I found staggering is that for every second an average car is driven, you may as well leave your phone charger on for an entire day 😐
whether carbon caputre or even carbon is the issue, it seems crazy to me, as mentioned earlier that we don't have CHP or district heating more commonly
Posted : 23/10/2011 7:52 pm
Well you see edukator - you do understand the issues - there is nowhere to put the shutters - no space above and below the window - no space at each side. Nor were shutters ever fitted. I don't know if planing would be granded but I doubt it as it would mean major restructuring of the windows which would not be allowed,
As for insulation above me - thats one of the issues. I have just at great expense had 100mm put in. There is no way of putting anymore in. You see its a 130 yr old building with a flat roof. That is however to to the the latest specs and should improve things.
The worst area is the area on the cheeks of the dormer windows - lath an plaster, air gap, wood, slates. No possible way of putting any insulation in there. I have tried.
Its the structure of the building that is the issue - but of course you know things about my building that are not known to others.
I have put in as much insulation as possible as I have repeatedly told you
Also if you read what I put earlier there is no heat from below most of the time.
He once watched a staged 25-minute TV programme, Don, all your years of hands-on experience and success, and university studies that support your view just don't stack up in TJ's world.
Don - If you wopuld just accept that you know nothing about listed buildings and that what youa re telling me is not what historic scotladn have told me.
Its pointless engaging with you as you keep on trying to tell me to do things that are impossible because of you lack of knowledge about my building and your lack of understanding of listed building regs as applied to my building - something I have a lot of experience of having worked with them for 20 years.
Posted : 23/10/2011 7:56 pm
What's the R value of the 100mm you put in, TJ? If did a bit of research it would be R=7. So is it three layers of 30mm 25-layer aluminium foil/polyester/foam (total thickness 90mm) which would keep your place warm or 100mm of rockwool or hemp or fibreglass or wood fibre with R=2 - woefully inadequate..
Posted : 23/10/2011 7:59 pm
Edukator - the issue is he does not know or understand the constraints I am working under. he does not ( as you don't) understand the building nor the regulations and how they are applied. Hence he and you keep coming to erroneous conclusions and state that I must do things that cannot be done.
Have either of you discussed this with Historic Scotland? I have. At length. Looking for ways to further improve the thermal performance of the building. Non of the things you have suggested can be done. None of them.
Posted : 23/10/2011 8:00 pm
Maybe you could just move to somewhere more eco-friendly?
Posted : 23/10/2011 8:02 pm
More intelligent? Maybe, but its certainly been rubbished by those who have made an emotional commitment to "green" energy and refuse to countenance any data or argument that maybe its not a practical solution to our future energy needs without us all changing our lives completely by living in inner city bubbles or living next door to where we work and reducing our travelling to the extreme unless its by bike or public transport. Its really not worth arguing with these people. They've climbed up the metaphorical loft ladder pulled it up after themselves and are sitting there with their fingers in their ears.
Posted : 23/10/2011 8:07 pm
Why should I accept your presumption that I know nothing about listed buildings or the authorities that deal with them? You stepping dangerously close to arrogance again. Youi clearly have nothing constructive left to say and have demonstrated time and time again your ability to discuss an issue without resorting to insults, so I'll leave you in you ignorance. Good luck.
They take your trousers down because you don't know how to deal with them, they probably get pissed off with your arrogance and attitude.
Which leaves behind an "eco-unfriendly building to be inhabited by someone else. Hardly a solution unless the planning rules are relaxed to allow sensible insulating measures.
Posted : 23/10/2011 8:09 pm
So what's the R rating of the isulating material you used, TJ? A description of the material is all we need to work it out if you don't know.
Once again you make the assumption that other forum contributors "know nothing", TJ. Before long you'll be telling us "we haven't got a clue". Other forum readers just see you refusing to reveal your gas, electricity and transmort use, and dissing pdfs published by the competent authorities.
Posted : 23/10/2011 8:11 pm
Well its fairly clear to me that you don't know anything much as you keep telling me to do things that are not possible and you keep showing your ignorance of it
I ask you again - what is your experience of insulation of 130 yr old listed buildings in a conservation area in Scotland?
Your experience of working with Historic Scotland is?
Its not my ignorance don - its your inability to accept that I know my building, what is allowed and what is not.
Edukator - the insulation was put in by contractors working for the council so I do not know what it was - its a green ( I think) semi rigid board 100 mm thick - it meets building regs suposedly. Looked like polyurethane foam
I do not refuse to reveal my energy consumption - I do not have the numbers. Its high - I can tell you that. A consequence of living in a building that is hard to insulate well - although its one of the best locally - as the snow stays on it a lot more than neighbouring buildings. All my external walls are lath and plaster to timeber to either slate or lead or roofing felt.
Those PDFs are general guidance. I know the specifics for my building because I have discussed it with historic Scotland. I know that in Edinburgh I can only replace the windows with replicas which precludes the use of triple glazing
It does amuse me that two people who don't even live in the same country and have had no dealings with the authorities know more about the building I own that I do and they know all these things that are possible to do despite historic Scotland refusing to allow them or it not being possible due to the construction of the building.
So yes - clearly neither of you know or understand the issues I have and have no desire to know. I know I have done as much as is possible
Posted : 23/10/2011 8:43 pm
"Salmond is hopping"
now that I would like to see
Posted : 23/10/2011 8:47 pm
Well he is a toad 🙂
Posted : 23/10/2011 8:48 pm
I've rubber stamped a lot more British planning applications than you, TJ.
Anyhow we've now assertained that the energy consumption of you home is very high and the insulation woefully inadequate. We also know that you are much keener on finding excuses than doing anything about it - much like the power company you started this thread about.
Posted : 23/10/2011 8:59 pm
Tandem, why should I answer your questions when you've refused to answer mine? But I will. My experience with CWI and loft insulation in 130 a year old building is zilch. But then again I have never claimed any thing different, so I'm not sure what you're trying to achieve with that. But if it makes you happy, who am I to complain?
And unlike Edukator's experience you'll just have to keep guessing on mine, it's more fun that way.
Posted : 23/10/2011 9:01 pm
So its established then - neither of you know anything about my building, my situation, or the regulations I have to work with.
Nothing either of you have suggested is a possible way to achieve a better thermal performance. You have also missed the most obvious one - secondary glazing. ( of which I have some)
so spending many thousands and many many hours fitting the best insulation I can is finding excuse rather than doing anything.
If either of you actually had something relevant and possible to suggest it would be useful. Instead yo just want to be ignoarnat and unpleasnat trolls. byee to both of you
Posted : 23/10/2011 9:11 pm
You have now just made my day. Wher the **** do you get off? You sir anre indeed an i***t of the highest order. 😆
unpleasnat trolls.
And this is the cherry. Show me the unpleasantness directed at you? I can show you the derrogatory comments and misguided assumptions you have, again, made about me, if anyone should be affronted, it's me. You know what that say about hot kitchens, don't you?
Posted : 23/10/2011 9:14 pm
don simon - Member
You are both ignorant and stupid - too stupid to understand the limits of your knowledge and experience.
Posted : 23/10/2011 9:19 pm
What's CWI and loft insulation got to do with windows? Zero experience in these areas will mean that I don't give advice here and if you care to look back you'll see that I haven't spoken about CWI or loft insulation because I do know the limits of my experience, unlike some. You're too easy Tandem. 😆
TJ in another not listening shocker!! 😯
Posted : 23/10/2011 9:20 pm
 Kit
This thread is really ****ing embarrassing to be associated with 🙁
Posted : 23/10/2011 9:30 pm
sorry kit - I forgot "don't feed the trolls"
Posted : 23/10/2011 9:34 pm
So we're both ignorant and stupid now, TJ. Time for bed I think.
The thermometer on my wall reads 19.2°C; the heat from three people, the TV and a computer has raised it by 0.2°C on a cold, star-lit evening. It'l still be nice and warm in the morning. Think about that as you get out of bed in your freezing attic, or do you leave the heating on greenhousing the planet all night?
Posted : 23/10/2011 9:37 pm
 Kit
In case anyone reading this is still interested in actual thread topic, this opinion piece is interesting:
http://www.guardian.co.uk/environment/2011/oct/20/carbon-capture-uk-european-funding
Posted : 23/10/2011 9:38 pm
I'm sorry that you don't think that indivuals taking responsinbility for reducing their own consumption is important. But hey, each to their own.
Posted : 23/10/2011 9:54 pm
Don - which is why I live a lower carbon lifestyle than many and why I have insulate my house as much as possible.
Posted : 23/10/2011 10:02 pm
Jeez TJ and Edukator. I thought all you eco-warriors were on the same side.
Posted : 23/10/2011 10:04 pm
DenDennis - That diagram is pretty meaningless as far as I can see by itself, maybe it might makes some sense in the context of its accompanying chapter. I don't understand why its crossed out eg shallow offshore wind with the line 'not near my birds' when offshore windfarms are being built having gone through the planning process where impacts on birds would have been assessed in EIA.
I had a quick look at the link and the first chapter I looked at on offshore wind was a bit alarmingly written:
Conven-
tional wisdom seems to be that shallow offshore wind (depth less than 25–
30 m), while roughly twice as costly as land-based wind, is economically
feasible, given modest subsidy; and deep offshore wind is at present not
economically feasible. As of 2008, there’s just one deep offshore windfarm
in UK waters, an experimental prototype sending all its electricity to a
nearby oilrig called Beatrice.
Starting a paragraph with the phrase [i]"Conven-
tional wisdom seems to be"[/i] is a bit worrying and I would suggest a lot of the technical aspects of that chapter are looking a bit dated already when you look at the depths of Round 3 zones and projects like Hywind II.
I've not read the rest but based on that I would bear in mind that it might be a bit dated already.
Posted : 23/10/2011 10:08 pm
 Kit
If you say so.
Posted : 23/10/2011 10:33 pm
 ojom
In other 'edge of the seat as it happens' related insulation and efficiency news, the wife n me bought 7 rolls of wool for the loft and the FIL fixed a buggered hallway window that was draughty and noisy to boot.
As you were Eco Soldiers.
Posted : 24/10/2011 9:07 am
Chapeau for Don Dimon on this thread.
TJ, as per usual, ignores the evidence that doesn't suit his argument and resorts to insulting the intelligence of those that disagree with him.
Posted : 24/10/2011 9:33 am
wwaswas - what evidence that does not suit my argument?
The kept trying to tell me I could do stuff that is specifically excluded because of their ignorance of my position.
Don Simon and Edukator - neither of them live in the UK. Neither of them know my building, neither of them have had any experience of dealing with historic Scotland.
I have specifically asked historic Scotland about replacing windows and the only acceptable replacements for my flat are wooden sash and case windows that are replicas of the original which completly precludes the use of triple glazing.
The two of them arrogantly assumed they could point out where I could do more and then could not accept that I know more about what is possible in my building than they do.
I have fitted as much insulation as is possible[i] within the constraints of the listed building in a conservation area.
[/i]
They were both extremely offensive towards me if you read the thread.
Posted : 24/10/2011 9:39 am
*Waves from Shropshire*
Posted : 24/10/2011 9:44 am
[i]wwaswas - what evidence that does not suit my argument?[/i]
A link to about 8 different suppliers of 'approved' double glazing where you insisted there was only one?
Posted : 24/10/2011 9:46 am
wwaswas -
Thats because there is only the one manufacturer who makes the type of DG units [i]that can be fitted into the type of windows I have to have fitted[/i].
Posted : 24/10/2011 9:49 am
Page 5 / 6
