Car Mechanics ... i...
[Closed] Car Mechanics ... is our car going to blow up?!
 Aus
[#498299]
Have a VW Passat Estate, 02. Over the last couple of weeks, have intermittently noticed a slight and brief petrol smell, only when first started in the day, disappears quickly and doesn't reappear when re-started that day. This morning, 2 mins after first starting, there was a steady trickle of petrol from under the tank (near the rear driver's side wheel) of about maybe 1/2 mug. It then stopped and hasn't re-appeared, even on starting the car, and driving around the block.
Any clues before the garage decide to replace everything in sight!
Posted : 24/04/2009 10:34 am
Nip over to the Honest John website and stick a post in the Technical Section. Place is frequented by experts and you generally get a reply within the hour. Ignore any sanctimonious posts from someone called L'Escargot, he takes PC to a whole new level.
Posted : 24/04/2009 10:39 am
Its either going to be a leaky hose (cheap part but depending on location could mean draining and dropping the tank) or a blocked evap circuit forcing a leak at a weak point (such as a hose or filler union). Assuming its not dripping near the exhaust you wont blow up (and even if it was you probably wouldnt but safer to assume this way!) but I would get it fixed ASAP. If it decides to drop another half-mug and someone drops a lit cig you could end up with no car at best.
Very hard to identify leaks like this until they decide to leak properly - the hint of petrol vapour takes a lot of tracking down 🙂
Posted : 24/04/2009 10:46 am
 Aus
thanks!
Posted : 24/04/2009 7:16 pm
Just drive along with the doors slightly open so if it does blow up you can make a quick escape. Keep a camcorder at the ready for some great youtube footage too.
Don't smoke.
Posted : 24/04/2009 7:34 pm
