...and if I can how do I do it?
Thanks!
Try [url= http://www.doubletwist.com/ ]http://www.doubletwist.com/[/url]
I've just this minute finished syncing my galaxy s (android) with itunes.
I used [url= http://www.samsunggalaxysforum.com/tutorials/how-to-sync-with-itunes/ ]these instructions[/url] can't see why the same won't work for your phone.
Burts suggestion looks a lot better than mine ๐
I've also got the Galaxy S. I tried the iTunes Agent first and did get it to work (the trick is to make sure that the SD card is "mounted"). But it copied everything over as a single, large playlist and didn't seem very flexible with playlists, podcasts etc.
The DoubleTwist player is better than the standard music player on my Galaxy and I've still only got 1 source folder of mp3 files on my home computer.
Double Twist looks promising! Thanks!
But how exactly does it work?
doubletwist here as well, although you can sync playlists with HTC Sync 3, I found doubletwist to work better.
Basically is reads all your itunes playlists, then you select which ones you want uploaded to your phone, very simple. Plus it's a much better music player on the phone as well.
I like double-twist, seems powerful for a free app.
Would I need to download it to my pc aswell then?
Yup, you need to download it to your PC.
