Can I fix my PIR li...
[Closed] Can I fix my PIR light to stay on all the time like a normal light?
I've got a PIR light on my garage which has stopped working, so I'm presuming the PIR sensor is knackered. Is there anything I can do to it to make it stay on all the time when it's plugged in?
Posted : 23/12/2014 7:15 pm
It may have a timer dial on the back, just wind it all the way out if so. Otherwise just rewire it.
Posted : 23/12/2014 8:12 pm
Usually if you switch it on then off, then back on again it stays on.
Posted : 23/12/2014 8:32 pm
Take it apart and bypass the the pir.
Posted : 23/12/2014 9:49 pm
Google it... A quick off-on-off-on or similar often bypasses the PIR and will make the light stay on permanently until dawn or when you switch it back off.
Posted : 23/12/2014 9:54 pm
The one on my house did the same, I spent a while fiddling with it and the on off, on off, on off thing worked on mine sometimes. In the end 6quid at wickes for a new non pir light seemed worthwhile!
Posted : 23/12/2014 10:40 pm
