Can I boost WiFi si...
[Closed] Can I boost WiFi signal in the man cave?
8 Users
Haven't got a clue with this kind of stuff....
The cave is about 20-25m from the router, talk Talk one if that makes any difference.
Thanks.
Posted : 21/02/2015 9:11 am
Move your wifi router nearer so there is less blocking the signal and / or get a wifi repeater to plug in in the man cave.
Posted : 21/02/2015 9:14 am
You can buy a signal booster and they work OK IME but this is inside a house
May need to pay more to get the range you need
http://www.scan.co.uk/products/edimax-ew-7438rpn-mini-n300-wi-fi-wall-socket-plug-extender-access-point-wi-fi-bridge
Posted : 21/02/2015 9:15 am
Would it be feasible to use a cable?
[url= http://pages.ebay.com/link/?nav=item.view&id=191491388947 ]Cat5e Ethernet Network Cable[/url]
Posted : 21/02/2015 9:44 am
http://www.turnpoint.net/wireless/cantennahowto.html
Or a PowerLan.
Posted : 21/02/2015 9:49 am
<ghetto hack>Try placing a 'baking tray' reflector behind the hub </ghetto hack>
Posted : 21/02/2015 10:18 am
 P20
I've got TPLink powerline adapters around the house for the PC, blu-Ray and a wireless one in the garage. It's got an Ethernet port for the Internet radio too
Posted : 21/02/2015 10:47 am
 P20
[url= http://www.broadbandbuyer.com/products/13610-tp-link-tl-wpa271kit/ ]this one[/url]
Posted : 21/02/2015 10:50 am
Thanks, I'll have a look at those.
The router is next to a window so has a 'clear run' up the garden and using an ethernet cable isn't an option really.
I like the sound of the plug in booster if it'll work with that distance?
Posted : 21/02/2015 11:11 am
Sounds like you have line of sight so have a look for boosters that will take an external ariel then add a directional ariel pointing at your router.
Posted : 21/02/2015 1:24 pm
