Can a house / room ...
[Closed] Can a house / room cause pneumonia / illness?
Sounds as if a dehumidifier, air purifier and possibly a supplemental fan (to help circulate air and get more passed through other units) could help.
Posted : 18/08/2017 11:33 am
I got a pretty cheap one but it was obvious as soon as I put it to the walls that there was damp. Something like this should give you a good idea.
Those prong meters aren't designed for measuring damp in old houses - they're for use on wood. They'll almost certainly give a false positive reading (they're much loved by folk selling damp proof courses).
A Victorian house is designed to "breathe" as someone else suggested. Then 21st Century Man comes along and hermetically seals it with modern plaster, paints, double-glazing, then wonders why everything is wet through all of a sudden.
Posted : 18/08/2017 11:46 am
Great news that the young one can come home. Hopefully you'll get to the bottom of the house issues soon
Posted : 18/08/2017 12:31 pm
 DT78
well damp meter turned up. my novice if the number is big it's bad shows full bar against a couple of suspect patched in the downstairs loo. all I can think is there is a old pipe in the wall as I've disabled the toilet
plus the chimney in the backroom (lower part removed downstairs at some stage) shows a big number round the ceiling, possibly not capped correctly.
hopefully Marin will be able to give a professional opinion later in the week.
starting to think buying a doeruper was not a great idea with young ones
Posted : 18/08/2017 1:41 pm
 DT78
"40-70% but anything above 60% can act by causing condensation points"
quick run around with the cheap humidity tester shows 57-61%, so not that bad really. I'm starting to think the smell / possible related health issues maybe from water ingress rather than a condensation issue.
Posted : 18/08/2017 2:30 pm
 DT78
Big thank you to John (marin) who went out of his way to pop round today. confirmed I've got a few things that are very likely to be leading to damp and need a closer look / fixing.
I might also try out one of those pumps subject to swmbo, and how much of my rapidly diminishing budget is left!
Posted : 23/08/2017 10:44 pm
Has the hospital told you what caused the pneumonia?
Posted : 24/08/2017 7:35 am
I doesn't help the immediate issue but if you had a full structural survey surely that should have highlighted damp! Maybe grounds for a claim against the surveyor/company.
Posted : 24/08/2017 7:53 am
 DT78
The pneumonia was viral, not bacterial, caused by adenovirus (sp?) so this would not be related to damp. Doesn't mean the other things (like my headaches) are not related, but there doesn't seem to be evidence of a really bad infestation.
The areas of damp are the top of a chimney/ceiling in the back room (ground floor stack removed) and in a downstairs loo likely a plumbing leak. The survey says something along the lines of 'no damp was found by testing likely areas'. Tbh the downstairs loo looks like it might have been like this for some time (its the original 30's lead pipework) and probably should have been picked up. Going to be a massive pita to sort as it needs the laminate up in the kitchen, meaning the island probably needs to be removed as well to get to the pipework that leads to that space
So how would one start a conversation about whether this should have been identified of the structural survey or not?
Posted : 24/08/2017 12:52 pm
Page 2 / 2
