Calling all sparky’...
[Closed] Calling all sparky’s - Light wiring puzzle
Hi, I’m hoping a singletrack Sparky can spot a simple problem.
We have two light fittings connected to a single switch so both lights switch on/off at the same time from a single switch.
Whilst fitting new light fittings yesterday, I copied the old wiring exactly and now one light doesn’t work.
Fitting 1 has 2 lives and 2 neutrals.
Fitting 2 has 1 live and 2 neutrals.
Does that sound incorrect?
Posted : 28/07/2019 12:47 pm
yes that is incorrect!
there are several ways of wiring lights and its really unclear from your description which has been used. Any pics? Have you a multimeter / testing screwdriver? You should have switched live at each fitting and also a permanent live probably at one depending how its wired.
My guess is you have two wires transposed. However it sounds to me like dodgy wiring and one to get a pro in to sort out what is going on.
Posted : 28/07/2019 1:32 pm
What is in the switch?
Posted : 28/07/2019 2:17 pm
That’s enough for me. Going to get a pro in. Thanks TJ.
Posted : 28/07/2019 2:25 pm
The problem you're having is you're assuming that re/black or brown/blue are lives and neutrals. It's not uncommon in lighting for a T&E cable to be used for switch wires, and should be sleeved accordingly, but people don't always (hardly ever). There is also many ways of wiring lighting, which is often a pain (improbable) to diagnose if you're not there with measuring kit.
Posted : 28/07/2019 2:58 pm
If you had copied the old wiring exactly the lights would be working.
Posted : 28/07/2019 3:24 pm
... assuming the old and new terminals are in the same place on the switches.
Posted : 28/07/2019 8:06 pm
