Built my 1st pergol...
[Closed] Built my 1st pergola...
16 Users
Rather chuffed with myself at the moment, I've done all the hard work and built our new pergola.
Never done any building/construction type stuff before so it's taken a while but the structure is up and solid.
Just need to do some tidying up, fill a few gaps and put the roof on...and guttering etc
Posted : 18/03/2013 11:57 am
<pedant>
Actually that'd most likely be an arbor, not a pergola. Pergolas are generally structures that span paths and are intended to be walked through, whereas arbors are structures you sit under. Yes I know you can walk through that one and the terms are often used interchangeably, but this is STW and we have standards to uphold!
</pedant>
PS - lawn needs reseeding, patio needs clearing of algae/moss and where's the bike?
Posted : 18/03/2013 12:11 pm
 DT78
What are you going to roof it with? I have a similar.... Pergola.....in my garden but not roofed
Posted : 18/03/2013 12:13 pm
Looks really good.
Out of curiosity, were you encouraged to have a go by all the DIY threads on STW?
Posted : 18/03/2013 12:15 pm
It was very wet when I did it so walking around/carrying big sticks has given the lawn a bit of a beating. Will be re-seeded when all done. Patio will also be properly cleaned. Bike in garage covered in sawdust 🙁
#DT: 10mm twin wall polycarb in bronze. http://www.theplasticpeople.co.uk/cut-to-size-twinwall-polycarbonate-opal-bronze-p-234.html Like this but have found a cheaper supplier, can't remember the name now
Posted : 18/03/2013 12:18 pm
~footflaps: thanks 🙂 No, it's been on the 'to do' list for a while. Finally got the money together to do it..
Posted : 18/03/2013 12:19 pm
nice. Get yourself a hammock and some anchors for it. This is where I spend summer evenings with a cold cider: did it spring before last. Two Wisteria are well on their way to filling in the roof now. Should be able to train leaders across the top this summer.
Might put a vine in a large pot at one end too.
Now have some roses coming up the barn walls as well. Must get a picture this summer when they are out.
[img] https://lh6.googleusercontent.com/-frR1FHeUsOE/Th3FzvMCGxI/AAAAAAAAAU8/HXFx7mT1VgA/s640/P1010028.JP G" target="_blank">https://lh6.googleusercontent.com/-frR1FHeUsOE/Th3FzvMCGxI/AAAAAAAAAU8/HXFx7mT1VgA/s640/P1010028.JP G"/> [/img]
Posted : 18/03/2013 12:22 pm
Very nice Stoner. Looks like 3 counties area?
Posted : 18/03/2013 12:24 pm
further along.
Posted : 18/03/2013 12:26 pm
For thepurist
[i]A pergola, arbor or arbour is a garden feature forming a shaded walkway, passageway or sitting area of vertical posts or pillars that usually support cross-beams and a sturdy open lattice, often upon which woody vines are trained. As a type of gazebo, it may also be an extension of a building, or serve as protection for an open terrace or a link between pavilions.[/i]
Posted : 18/03/2013 12:28 pm
Ah, so it is a [i]pergola[/i] 🙂
in your face 'thepurist'... 😆
Posted : 18/03/2013 12:32 pm
I love a building thread.
Here's a hexagonal variation.
Posted : 18/03/2013 12:49 pm
Back atcha stevied 🙂 Here's some webby stuff to back up the best part of a decade designing gardens for a living...
o
http://landscaping.about.com/cs/lazylandscaping/g/pergola.htm
http://www.jacksgardenstore.com/blog/2009/12/what-is-the-difference-between-an-arbour-and-a-pergola/
http://m.wisegeek.com/what-is-the-difference-between-a-pergola-and-an-arbor.htm
Top work all round folks.
Posted : 18/03/2013 1:10 pm
Here's a couple of pics of my first pergola which I built last year for someone
[IMG] [/IMG].
18 foot span between front posts, 12' posts 9" x 9". Very heavy. Knee braces all recessed mortice & tenon jointed & pegged a la timber-frame. Beams are 22' 9" x 3"
[url=[IMG] [/IMG]]null
All beam & rafter tails cut to the golden ratio...
Posted : 18/03/2013 1:12 pm
very nice touches.
I fancy having a go at this once I've finally finished the workshop off......
Posted : 18/03/2013 1:22 pm
Nice one! There's nothing quite like the feeling of tackling something completely new like this and getting a result.
Posted : 18/03/2013 1:26 pm
That's a lovely job tymbian. Well Jell 😉
Posted : 18/03/2013 2:00 pm
#thepurist: This seems to go against your thoughts (from your link 😯 )
Another difference between a pergola and an arbor is seating arrangement: an arbor often features a bench on which visitors can rest and find protection from inclement weather, while a pergola can cover an entire area designed for seating, a table, or other types of arrangements. Pergolas sometimes cover patio areas and offer shade from sunlight, and chairs and tables can be set up on the patio underneath the pergola to form a comfortable and attractive shelter. An arbor is much smaller and only allows only one or two people to sit beneath it at one time, as it is meant as a temporary shelter only.
Posted : 18/03/2013 2:03 pm
I am surprised that we have failed to establish whether the OP's cooking equipment under cover is gas outdoor cooker or 'proper' BBQ. I think we need to know!
Posted : 18/03/2013 2:37 pm
Sadly it's an outdoor cooker : [img] [/img]
Posted : 18/03/2013 2:43 pm
Oh well, at least its hidden! 🙂
Posted : 18/03/2013 3:00 pm
Dagnabbit!
<gritted teeth>
Nice pergola stevied.
</gritted teeth>
Posted : 18/03/2013 3:43 pm
won't you block out your light when stuff grows over it?
Posted : 18/03/2013 3:45 pm
I trained a vine over mine: you get shade in high summer (if we ever get one) but the light is let through for the other three seasons. I think it's ideal.
Posted : 18/03/2013 3:50 pm
That one will be coming down and be replaced with some nice* lighting which the wife has yet to choose.
thepurist: :mrgreen: why, thankyou..
*it might be nice in her eye, I may hate it..
Posted : 18/03/2013 3:53 pm
@ stevied..nice work. It's a great feeling standing back and looking at a finished project eh? Bet your still doing it.
Those twin-walled polycarbonate roofing sheets are a good idea and they will help structurally when it snows..( don't underestimate the weight of 6 or 8 inches of snow ).
Have you got any flashing planned for the brick & roof junction? ( think about the rain splasing up off the roof onto the brickwork ) flashing will provide a bit of protection as well as stopping water running past the roof and down the wall.
Posted : 18/03/2013 5:28 pm
@tymbian. Thanks mate, yeah, still keep going back in the garden to have a look at my handiwork...lol.
Am planning on using some flashing as recommended. Will paint it all up, get the roof on, then do the flashing 🙂
The list of things to do just goes on and on but I'm enjoying it..
Posted : 18/03/2013 6:28 pm
How very topical....I was thinking of knocking up some kind of pergola in the back yard....nothing on Stoner's scale mind just something to tidy up the unused bit of the garden and to show how sad I am these days I did a sketch up.
Posted : 18/03/2013 10:03 pm
So, after what seems like ages, the pergola is pretty much finished. I know some of you will probably hate it as it's not wood coloured and has a proper roof but...
the house is only a few years old and the idea of the pergola is to extend the downstairs area as it's quite small. I found a colour that's very close to the paint in the kitchen so, when you walk in, it does look like part of the house rather than an add-on. We also wanted to be able to use it lots and with our rubbish summers the roof was necessary.
Just need to get a water butt, finish the guttering and hang the pendant heater..
Rather proud of myself :mrgreen:
[URL= http://i729.photobucket.com/albums/ww299/deesta-pics/IMAG1505_zps93112174.jp g" target="_blank">http://i729.photobucket.com/albums/ww299/deesta-pics/IMAG1505_zps93112174.jp g"/> [/IMG][/URL]
Posted : 21/05/2013 7:46 am
Looks very practical 🙂
What's the roof material?
Posted : 21/05/2013 7:54 am
Did you reseed the lawn and clean the patio because someone on here told you to? Or had you always planned to do it?
Posted : 21/05/2013 7:59 am
Aye, any glass in that roof, above the door & window mebbe?
Posted : 21/05/2013 8:00 am
10mm Polycarbonate twin wall.
Always on the 'to do' list..
any glass in that roof?
No glass, just bronze polycarb..
Posted : 21/05/2013 8:19 am
Woodwork looks good - what did you use, 'Garden Shades'?
Posted : 21/05/2013 8:39 am
What's the gutter draining into?
Posted : 21/05/2013 8:45 am
~sharkbait: yes, country cream
~AS:
tho currently into the border 😳
Posted : 21/05/2013 8:51 am
