Brownies recipe
[Closed] Brownies recipe
Just tried my hand at baking brownies for the first time ever tonight.
The final result tastes alright, but didn't rise so I've got very dense brownies about 6mm thick. I've basically made cookies. No idea what went wrong, am open to suggestions.
I'm going to try again tomorrow. In the meantime, does anyone have any personally recommended recipes I could have a punt at?
Posted : 21/03/2013 11:43 pm
Hmm, usually just go for a basic book or net recipe, but then add some coffee and peanut butter. Also it is important not to overcook them as they dry out quickly. Sounds like your were missing a little something though, was the pan too big? 6mm doesn't sound like the mix was too deep in the first place.
Posted : 22/03/2013 12:25 am
Could well have been that TBH - I thought when I stuck it in the oven that it was a bit thin.
Posted : 22/03/2013 12:28 am
 grum
Made these very successfully recently.
http://www.jamieoliver.com/recipes/chocolate-recipes/bloomin-brilliant-brownies
Posted : 22/03/2013 12:32 am
Good old Delia - work every time 🙂
http://www.bbc.co.uk/food/recipes/fournutchocolatebrow_67259
Posted : 22/03/2013 10:34 am
[url= http://www.bbcgoodfood.com/recipes/2882/chocolate-brownie-cake- ]BBC Good Food Recipe[/url]
This one has been great for me. Stuck in a square tin for small brownie squares. Replaced the Pecans with Glace Cherries, and it was superb, rich indulgent and very yummy.
Posted : 22/03/2013 10:39 am
[url= http://www.foodnetwork.co.uk/recipes/salted-peanut-caramel-brownies.html ]Salted Peanut & Caramel brownies[/url] made these a few times and have been popular with my victims.
I'd never made a cake before when I first tried them so must be easy enough.
Posted : 22/03/2013 10:48 am
or
Posted : 22/03/2013 10:49 am
I use a heavily modified version of Jamie Oliver's (linked to above). A local cycling cafe buys them from me so yes, they're very good. 🙂
Exact recipe is top secret... 😉
Posted : 22/03/2013 10:59 am
The wife makes these all the time, they never last long...
[url= http://uktv.co.uk/food/recipe/aid/654053 ]NOM NOM CHEESECAKE BROWNIES[/url]
Posted : 22/03/2013 11:11 am
My recipe (more or less the BBC good food one) uses a bag of broken up [u]salted[/u] pecan nuts, as opposed to the measly 50g, which makes any peanut based brownie vastly inferior.
I suggest you try it out.
Posted : 22/03/2013 11:12 am
Cheers all.
Food for thought, as it were.
Posted : 22/03/2013 11:18 am
I was all set to make Delia brownies tonight (for a weekend biking in Wales!) and now i'm all confused... 😉 😆
Posted : 22/03/2013 11:19 am
Guy I work with made these inappropriately named [url= http://whatsgabycooking.com/slutty-brownies/ ]Slutty Brownies[/url] (although he called them Triple Layer Brownies for the easily offended)
Om nom nom, indeed.
Posted : 22/03/2013 11:42 am
Mrs Sprocketjockey had a hand in this recipe.... uses mayonnaise rather bizarrely but the results are really light and delicious:
https://www.hellmanns.co.uk/recipes/dessert/posh_brownies.aspx
Posted : 22/03/2013 12:39 pm
I like the look of those triple layer ones. I always use Nigellla Lawsons recipe from her "Domestic Goddess" cookbook. 6 eggs, a whole block of butter, several bars green and blacks chocolate. No expense spared brownies, and incredibly good. Mmm, not made any for ages...
Posted : 22/03/2013 1:16 pm
You're a cruel woman redwoods - I am now sat at work and all I can think about are those triple layer brownies (slutty brownies just sounds wrong.....!) 😆
And I obviously work in the wrong place!!
Posted : 22/03/2013 1:24 pm
Brownies don't rise as much as a normal sponge cake does - not as much raising agent and generally a heavier mixture. I've made the BBC ones before and various other recipes and almost all of them sink after coming out of the oven into dense gooey loveliness!
Posted : 22/03/2013 1:30 pm
 edd
[s]Want[/s] [i]Need[/i] chocolate brownies now...
Posted : 22/03/2013 1:37 pm
Slutty brownies recipe bookmarked! Thanks Redwoods.
Posted : 22/03/2013 2:11 pm
top nommage!
Posted : 22/03/2013 2:16 pm
Miss NT, this colleague made them, special like, for Red Nose Day Cake Sale at work recently (although there is still way too much cake present in this office!).
They are beyond evil in a totally died-and-gone-to-heaven way. Nicest brownies I've ever had (with the exception of Hel's brownies on a Peaks Pootle once!). Might attempt them for that weekend you're up next 😉
Posted : 22/03/2013 2:23 pm
From Mrs B
Makes: 12
Preparation Time: 15 minutes
Cooking Time: 30 minutes
You will need
33 x 23 x 5-cm baking tray, lined with greaseproof paper
200g dark chocolate, roughly chopped
175g unsalted butter
325g caster sugar
130g plain flour
3 eggs
icing sugar, to decorate
Method
1. Preheat the oven to 170°C/325°F/gas mark 3.
2. Put the chocolate and butter in a heatproof bowl over a saucepan of simmering water (do not let the base of the bowl touch the water). Leave until melted and smooth.
3. Remove from the heat. Add the sugar and stir until well incorporated. Add the flour and stir until well incorporated. Finally, stir in the eggs and mix until thick and smooth.
4. Spoon the mixture into the prepared baking tray and bake in the preheated oven for about 30 to 35 minutes, or until flaky on the top but still soft in the centre. Be careful not to overcook otherwise the edges will become hard and crunchy. Leave to cool completely before dusting with icing sugar, to decorate.
Posted : 22/03/2013 2:24 pm
