ive got Shimano SLX M666 brakes and Avid HS1 rotors, thay were working fine but noe when i pull the front brake hard the forks and handlebars shudder any idea?
Posted : 11/06/2012 9:53 pm
Everything done up tight? Anything spilled (contaminated) onto the pads/rotor?
Posted : 11/06/2012 10:38 pm
Loose headset? Brake loose on the stanchion?
You'd probably get a better response from the Bike Forum to be fair. Over here you're as likely to get Parkinsons? as a suggestion.
Posted : 11/06/2012 11:09 pm
Check caliper bolts are all tight.
Posted : 11/06/2012 11:15 pm
Get you wheels balanced
Posted : 12/06/2012 4:50 am
