No swirling, no vinegar, doesn't even seem to matter how fresh the eggs are.
Get the water to almost boiling, then put the eggs into the water in their shells and roll them around gently for 10 seconds - then crack them into the pan. Can do several in the same pan.
Super easy and very consistent/aesthetically pleasing results.
Try it!
What jekkyl said
I can't get on with poaching inserts - bottom ends up overcooked, top not at all.
We just buy fresh eggs and poach directly in a frying pan of boiling water.
If they've gone past fresh we just scramble them instead.
Eggs done in a poacher like that look revolting. Straight in the water is how it should be. I will try groom's method tomorrow.
Normally get decent results with a bit of a swirl in the water. Can't understand how anyone could use vinegar.
Poaching inserts are right up there with e-bikes IMO. 😉
Might try OP's tip this lunchtime, fancy a couple of poached eggs on thick-cut, buttered toast. 🙂
Best tip I had was from this forum.
Verbatim...
Warm eggs in a bowl of warm water.Frying pan of water with just enough water to cover the egg.
Boil water & turn off heat. Just as water stops bubbling, drop in egg. Let it sit there for a couple of mins, spoon a bit of water over the top of the egg for a minute.
Before that I was a clingfilm guy. Really shit when compared to the above method.
how does the look affect the taste?
I get good results using a poaching pan, a tiny bit of oil rubbed round the thingy to stop it sticking and they pop out onto toast like little boobies. 😀
Silicon poach pods work better than a poaching pan. Still frowned upon by the purists of course.
Best tip I had was from this forum.Verbatim...
Frying pan of water with just enough water to cover the egg.Boil water & turn off heat. Just as water stops bubbling, drop in egg. Let it sit there for a couple of mins, spoon a bit of water over the top of the egg for a minute.
interesting, ill have to try that. how warms the water and how longs the warm-up?
tried OPs method and wasnt that happy with it. maybe i left it in the shell a little longer, but there was a trade-off between no straggly bits and some of the 'warmed up egg' sticking to the shell as i broke it to plop into the water, so less egg on plate :-/
i also struggle with the egg-poaching pan, never seems cooked on the top.
I use hot tap water so probably around 60 degrees for as long as it takes to boil enough water (in a kettle) for your pan. I heat the frying pan as the kettle is boiling and then go on with the bubble tip above.
Edit : I don't spend a minute splashing the top with water; a few splashes should be sufficient. Lift out, let it drain for a sec and dump it on the toast or whatever base you're using. Or straight down if you're part of the Hairbear Bunch...
Use cling film. And a small ramikin. Line the ramikin with cling film, drop of butter and seasoning, crack the egg in, "spin" the cling film so it makes a bag, tie it up and drop it in the water. No vinegar, no watery eggs and perfect poachies.
I didn't claim that but it has been demonstrated that it does. Personally I like food to look good on the plate.
Was going to have a couple of poached eggs for lunch. Opened STW on phone and, lo, here was this thread.
Tried the method. One eggshell cracked.
Eggs were usual fluffy mess.
Might have to try a couple more just to be certain...
Not a bad result this lunchtime. About the same as the normal swirl method.
Silicone poach pods here too with a good smear of butter inside.
Don't care about the purist view, it's easier than frying.
I'm not too bothered about looks as long as they are a good consistency, not over-cooked or hard yolk.
Having chickens I eat a lot of eggs.
My method is - bring water to boil in frying pan. Crack egg/eggs into pan, when the water is just about to start to begin boiling again, knock gas right down to lowest setting and leave until toasts are done.
A quick lap of the water over the yolk tops and you're done.
No vinegar or swirling and surprisingly good results.
Not perfectly uniform, but then eggs don't come out of chickens all the same anyway!
i think if the eggs are fresh then theres not much can go wrong with the straight in the pan method. ive seen the difference by doing a fresh egg and a not so fresh egg at the same time and its true, the fresh eggs stay together.
clingfilm would be my go to method if it wasnt a faff so im hoping the OPs method gets me a good result. ill probs try it tomorrow.
Lots of experimenting has occurred in the White household recently. I'm still somewhat eggbound as a result.
The most successful method was to boil a pan of water then turn the heat right down, so no boiling water bubbles are present. Crack two eggs into a ramekin and gently lower this into and under the water, before tipping the eggs gently into the bottom of the pan. When they whites have some structure, gently tease the two eggs apart. Two minutes in the hot water and you are done. Best served on marmite toast with a good deal of pepper IMHO.
We have been experimenting with poaching in the Instant Pot, works surprisingly well and very consistent results considering you cant see whats going on there. Who would have though that pressure cooked poached eggs would work so well!!
Those pot things are ok but it's not really the same.
I've had very consistent results with the method on 3 different batches of eggs. Possible they were all super fresh but they were from a supermarket so unlikely.
Will post pics next time but they are beautiful. 🙂
just had 3 poached eggs on toast using OPs method. hot water out the tap into a pan, eggs in pan whilst kettle boils, fill a frying pan with kettle water, keep pan on lowest setting so no bubbles, crack eggs into pan.
worked a treat, best poachers ive had in a long time. ill be er.... performing more tests next week 😀
thanks OP
You monsterthey were from a supermarket
PLease they were organic
+1 aphex cling film method
booty eggs an f all mess!
You are all genuinely odd.
Boil water.
Add eggs.
Wait.
Remove eggs.
What in the name of Zarquon is wrong with that?
I really don't get the issue. Boil water, drop temp a touch, swirl, put in eggs, leave 2, maybe 2.5 mins. Serve. Easy.
You monster
You Philistine more like. Your'e an unlucky person If you have to rely on supermarket eggs. I pay £1.50 a doz for free range from a bloke with chickens in his garden. 🙂
Silicon pouches here too, poaching pans take ages.
What a load of fuss.
Boil water, turn down to barely breaking surface, splash of white wine vinegar, as eggs, 2 mins 30, done. Poach pods are toss.
Poach pods are the business.
I like my eggs to taste like egg, not vinegar!
The vinegar thing is total nonsense. Makes no difference whatsoever.
Just so you all know. No vinegar required, no swirling. Nonsense.
Boiling water, remove from heat egg goes in. 2 mins later remove and enjoy
It does. It makes the egg taste shit.
If the egg tastes of vinegar, you've put too much vinegar in. And it does make a difference to how intact they stay.
Don't get all this frying pan nonsense though.
Source: custodian of many ex battery hens and not being able to bloody give away all the eggs these amazing creatures produce!
Lots of experimentation time...
Boil water in frying pan, I have one with a glass lid. About 1.5 inches of water.
Once boiling turn gas to low
Crack eggs in
Put lid on
Basically the steam in the pan cooks the top of the eggs
Don't overcook / allow to harden obviously
Done
Those pods and special pans do not make poached eggs.
Keeping it simple is best, but does require fresh eggs. Otherwise, drain off the watery white by cracking the egg into a slotted spoon, then poach as normal.
Point into the distance and say "look at that massive cockerel". At which point the hen will look towards where you're pointing. Now you have her successfully distracted, swiftly remove the egg from under her whilst she's looking the other way.
Hmm, I was hoping for some killer eggs here.
one egg is un ouef
That's what I used to say, and I can do it fine that way too but the way I described works better.
Glad you got on with it sadexpunk! Everyone who didn't, you're doing it wrong.
I like to poach them in a tablespoon of olive oil....can't fail....
Those poachers and silicone pouches....If only there was a more natural way to cook your eggs. If only they sold them in some sort of holder or casing that you could put in the boiling water and remove them from later.
Just tried the OP's method and it worked very well.
you are all over thinking it. Still water and drop distance are key.
boil the water in kettle, add to a frying pan don't go mad with the amount of water
bring to boil, turn down, wait till water is completely still.
crack the egg on a mug not the pan
open egg immediately over the still water so it doesn't have far to drop.
put toast on
I'm not interested in taking credit for it because it wasn't my tip originally but in the interests of clarity perhaps Sadexpunk can tell us which method he actually used as his example technique on the other page reads remarkably similar to the one I posted...
Sad's : hot water out the tap into a pan, eggs in pan whilst kettle boils, fill a frying pan with kettle water, keep pan on lowest setting so no bubbles, crack eggs into pan.
Mine : Warm eggs in a bowl of warm water.
Additional - I use hot tap water so probably around 60 degrees for as long as it takes to boil enough water (in a kettle) for your pan. I heat the frying pan as the kettle is boiling and then go on with the bubble tip above.
OPs : Get the water to almost boiling, then put the eggs into the water in their shells and roll them around gently for 10 seconds - then crack them into the pan.
Also...
Heh
Oh well, in the end I couldn't be bothered to change my routine. So hot, not boiling water it was, a little vinegar, crack the eggs straight in.
Delicious and nice looking eggs.
Successful pre-dipping attempt this lunchtime here. 3 pretty old eggs (display un 5ht March, Best before 12th - will I die?) and definitely less of a milky mess than I'd usually get with eggs that old straight from the fridge.
I did invoke the marmite the toast before placing the eggs on sub clause which might be controversial to some.
Your first mistake is putting eggs in the fridge. You're not American, stop that.
This seems to be one of the most inconstantly answered questions on the internet! Eggs in fridges definitely last longer; but they degrade faster in the cold; but they might take on tastes from other stuff in the fridge; that they need to remain a constant temperature so the fridge is the best place in the home; but you can't smell if they are off if they are cold; that they are only stored at room temp in the store as they would get condensation on the shell on the way home and as its porous thats a great way for it to take in bacteria.....and on and on....
You're overlooking one important factor. This is STW, therefore I'm right and everyone else is wrong. (-:
The whole thing of putting eggs in the fridge is because the US treat eggs differently. By law in the US eggs have to be sold washed which potentially damages the shell and increases the risk of salmonella infection, in the UK the opposite is true and eggs [i]cannot[/i] be sold washed, we mitigate the risk of salmonella by inoculating our hens. This is where the contradictory advice comes from.
If you put eggs in the fridge, as you say, you risk contamination from other strong flavours like smoked cheese, cut onions etc. It's not necessary.
^^^^ egg school day which is good. Still staying in the fridge though.
I've a Lakeland microwave poacher thing which a mate recommended. Tried it and went straight back to the pan method. Pretoast the toast to ensure it's ready when the eggs are.
Ah, got it. This is an interesting read.
http://www.businessinsider.com/should-you-refrigerate-eggs-2014-7
This is of course hugely important. The buttered toast needs to be ready just as the eggs are coming out of the pan. The timing is critical.
Marmite? With something as delicately wonderful as a poached egg? No thanks.
OP, it worked for me fine, a good tip if you want to do multiple eggs. I did pop a small amount of vinegar in and my eggs were about, hmmm 3 or 4 hours old 🙂
A poached egg? With something as delicately wonderful as Marmite? No thanks.
With my method on the other page there's no water ,no mess and you get all the egg.
Most importantly you can easily do it at work.
It means that you can easily do Parma ham, dark green leaf with a poached egg on top for lunch. Total joy.
Eggs boiled in a kettle, now yer talking....
You clearly don't understand what poaching is.
We eat loads of eggs as we've our own hens and ducks. We just use the saucepan method, no problems. Again as a few have said, use the freshest eggs. The older ones come apart a bit but still taste great.
I really can't understand all the fannying about? with eggs. 😉
I just ate poached eggs done the old school way, frying ban, water off boil, i love them. Anyway, i keep eggs in the fridge as my catering tutor told me the bacteria on the shell surface can pass through the shell at room temps.
Maybe false but she was a good chef so i believed her.
I used to work at an egg wholesaler and they weren't refrigerated there.
Fresh eggs get poached in the pan, not so fresh get boiled in the shell for 6 mins, then stop cooking by putting in cold water, shell and there you have it, cooked but soft eggs, they aren't poached but are a million times better than those plastic poacher travesties.
I guess this is something that comes naturally because I've never had to rely on bespoke pans, vinegar or cling film.
My own tip, if you've got to knock up a load of them for the family, I use the wok, half full of water to stop them moving about too much.
Incidentally,
Why are you all using frying pans? That seems suboptimal to me, you're using a pan a foot across to cook something the size of, erm, an egg. What's the thinking here?
I'm not cooking one, two to four generally and I want them separate.
They are eggs, they come in a ready made cooking vessel called a shell. Just fing boil the egg
another success, same method as before topped with black pepper, chopped chillis and feta cheese.
oops, just re-read first page, it is indeed your method that im using teasel rather than OPs, so thanks for that and apologies 🙂
FWIW i tried OPs 'dipping in boiling water' method before but when cracking the eggs, a thin lining of egg was sticking to the shell, so wasted egg. admittedly not much, but with teasels 'tap water' method this isnt happening.
theyre turning out so well theyre overtaking scrambled eggs as my favourite now.
teasel wins 🙂
Despite sadexpunk's confusion I think a consensus is developing that I am [i]spectacularly[/i] correct.
Edit: I don't get the frying pan thing either. Remain to be convinced about the fridge also.
No probs, man. Like I wrote, it's another forum user's words I used. I was an advocate of the clingfilm method until I tried the frying pan idea.
Lots of eggs in one sitting.
*belches*
You should write a book.
[b]Egg Cuisine by edhornby[/b]
Weirdo.
Got to say thanks for this tip, it went down exactly as described and earned me brownie points, - ta.
[i]Strictly speaking[/i] eggs cooked in any of those pod gadgets are [i]coddled[/i], not [i]poached[/i]. Just saying.
Thanks op..used this method the other day and worked a treat
I tried (for the 1st time in my 60 years) this morning... boiling some water in a smallish saucepan, (in the meantime breaking 2 eggs into a cup) took the pan off the boil & swirling the water then pouring the eggs in & putting the pan back on for a few minutes. No vinegar.
Spot On!
Had them on toast with Pate
(& for the record they were free range (£1.50 a dozen) & straight out of the chiller)
Eager to try the op idea. Though I have good results with cracking the eggs into an espresso cup or small mug and pouring it in to the water slightly submerged.
