I am looking for some stainless m5 * 100mm or longer countersunk socket headed bolts and m6 versions of the.
Have tried the usual places but to no avail.
They are for attaching a hasp and staple to a shed door.
Alternately can anyone suggest another type of fixing? Holes on the hasp are 6mm and holes on the staple are 5mm. The bolts need to be a min of 90mm long to get through the reinforcement on the door.
Cheers.
look on sailing websites
[url= http://www.pinbax.com/index.asp?uid=34619 ]http://www.pinbax.com/index.asp?uid=34619[/url]
http://www.baselinemarine.com/shopexd.asp?id=19791
Could you not use a round headed coach bolt? Worst case you'll have to drill a mm or so bigger hole through the hasp & staple. Theres no way anyone is going to be able to grab/undo them whatsoever
Carlos - I have heat treated the hasp and staple so there is no way that I can drill through it now.
a2a4 in southampton has loads of stainless bolts
if you can't see what you want he can prob get it for you
no idea if he's cheap though
You could use two bolts facing each other with a length of all thread studding in between connected by two long studding connector nuts.
It's not a tidy solution and you'd need to make the hole in the door big enough to clear the nuts, but it's all readily available stuff.
Un-heat treat the hasp and staple, drill out, re-treat.
Coach bolts. Something will give. Either the hasp or the square bits next to the head and they will fit nicely as long as they nearly fit. Big spanner helps!
