Boiler vibrating ev...
[Closed] Boiler vibrating even when off?
10 Users
The boiler has started making a vibrating noise,I've even turned it off at the mains and it's still making a vibrating noise,does anyone have any ideas what it could be plz?
Posted : 07/12/2011 6:35 am
The flue kit with wind being blown in it from outside???
Posted : 07/12/2011 6:42 am
Run?!
Posted : 07/12/2011 6:53 am
Don't think it's that sounds like its the pipes and it's intermittent ?
Posted : 07/12/2011 6:55 am
Can't understAnd why it's doing it with the boiler hot..
Is the water coming out the hot taps boiling hot?? We had tons of probs with our old Vokera..
Rattling noises, cutting out constantly. BG out about 10 times till someone realised the thermostat was gubbed..
Been going fine since.
Posted : 07/12/2011 7:39 am
I've turned all the power off to the boiler and it still making a noise,seems to be louder in the bathroom the boiler is in the bedroom.
Posted : 07/12/2011 7:45 am
 jeff
Dodgy pump perhaps? Have you turned power off to the pump as well as the boiler?
Posted : 07/12/2011 8:20 am
Turned the boiler off at the mains switch so there's no power going to it at all.
Posted : 07/12/2011 8:37 am
Posted : 07/12/2011 8:38 am
Sorry. Meant making noises when off..
Posted : 07/12/2011 8:55 am
I have a dodgy valve which sends a signal to the pump sometimes. This means the pump circulates even when everything else is off. Not a real problem but you might have a similar issue.
Posted : 07/12/2011 9:05 am
Is the varnish dry yet ?
Posted : 07/12/2011 9:09 am
Varnish?
Posted : 07/12/2011 9:45 am
Doesn't the pump continue to run, even when the boiler is off, if the temperature is over a certain amount. I know that while the heating is on with our system, the boiler will fire, then go out, but the pump still sends the water round the system.
Could be that you have a poorly pump (in the airing cupboard usually) that is causing the vibrations....
Posted : 07/12/2011 10:00 am
Would a pump run even with no power at all to the boiler,what would be powering the pump?
Posted : 07/12/2011 10:53 am
I am not sure whether the pump gets it's power from the boiler or not; I suspect not.
Easy way to check if the pump is your problem would be to stick your hand on the pump while the boiler is 'off', but vibrating. You can normally feel it pumping.
Your pump might have a variable speed control on the side, normally a 3-speed knob that you can twiddle.
If you increase or decrease the speed of the pump & notice a change in the vibration of the boiler, then this might also help to pinpoint the problem.
Posted : 07/12/2011 11:12 am
The pump is not magic! It will not run if the power is turned off!
Posted : 07/12/2011 1:19 pm
Mine is mouse driven.
Posted : 07/12/2011 1:21 pm
Have you tried just sitting on it, like you do with an over excited washing machine?
Posted : 07/12/2011 1:24 pm
