Bit of a challenge ...
[Closed] Bit of a challenge : Alloy Wheel Center Caps
14 Users
Very OT, but worth ago.
I have some alloy wheels on my car, and I have "lost" one of the center caps which cover up the bolts on the alloy wheel and I am damned if I can find any replacements.
The outside width of the hub which I measured last night is 165mm.
So anyone have any idea where I can track some down
Posted : 15/08/2013 11:06 am
Main dealer 😉
Posted : 15/08/2013 11:21 am
Make model of wheel?
Ebay breakers main dealer/ wheel manufacturer. Or silver tape.
Posted : 15/08/2013 11:30 am
Give us a picture of the wheel.
Posted : 15/08/2013 11:43 am
Scrap yard??
Posted : 15/08/2013 11:46 am
Renault or Vauxhall?
Posted : 15/08/2013 12:27 pm
A car park
Posted : 15/08/2013 12:34 pm
Its a replica VW wheel.
And it looks like:
[URL= http://i9.photobucket.com/albums/a91/richc666/IMAG0262.jp g" target="_blank">http://i9.photobucket.com/albums/a91/richc666/IMAG0262.jp g"/> [/IMG][/URL]
Posted : 15/08/2013 12:36 pm
Essentially its a little plastic hub cap with 165mm diameter and I am damned if I can track one down.
Posted : 15/08/2013 12:37 pm
165mm? Are you sure?
http://www.ebay.co.uk/bhp/vw-centre-caps-70mm
Posted : 15/08/2013 12:39 pm
So who makes the replica wheel?
Posted : 15/08/2013 1:40 pm
too small, I need the entire bit, here is a picture of the wheel with the missing one.
[URL= http://i9.photobucket.com/albums/a91/richc666/IMAG0263.jp g" target="_blank">http://i9.photobucket.com/albums/a91/richc666/IMAG0263.jp g"/> [/IMG][/URL]
no idea who makes it, as I couldn't find any markings
Posted : 15/08/2013 1:42 pm
It's still not 165mm though surely? That would make the wheel about 20" or more?
Or is my maths really terrible!
Posted : 15/08/2013 1:45 pm
 luke
So I think you've got an RS8 replica wheel.
Are you sure 165mm...the biggest seems to be 145/146mm?
Posted : 15/08/2013 1:49 pm
Best thing to do imo is remove one of the ones you still have and clean it up, on the back side should be a part number something like - 3b0 601 149. Which if you type into ebay comes up with quite a few that look similar.
That does look like an after-market wheel though as there seems to be a lot of wheel bolt holes, ie suitable for multi fitments. Should be Ok as I'd guess the centres are all the same anyway
Edit - You know they are replicas, coz you said so. Oh and they are Audi A8 replicas
Carl
Posted : 15/08/2013 1:56 pm
OK thanks for the help, I will lever off another one and see what I can find.
They are very big which seems to be making life hard.
Posted : 15/08/2013 4:08 pm
Hi, were you able to get the part number? I have exactly the same wheels and the same problem however all four of my centre caps were stolen so i can't get the correct part number. My wheels are 17" and none of the caps i've found on ebay fit.
Posted : 21/08/2013 7:30 am
Sounds like richc has been poaching caps - and maybe collected a few spares at the same time... 😈
Posted : 21/08/2013 7:34 am
What has the cap diameter go to do with wheel size? Or am I missing something?
Posted : 21/08/2013 10:41 am
Terrible. 😉
165mm is a fraction over 2.5". You're thinking of 165cm, which would be 6.5".
Posted : 21/08/2013 12:16 pm
Im confused. Wouldnt 165cm be 5ft 4inches?
Posted : 21/08/2013 12:27 pm
I bought a set of 155cm caps which were the right size on the outer edge but the centre clips to secure the caps were the wrong size.
Posted : 21/08/2013 5:03 pm
Sorry, left out the decimal; 16.5cm = 6.49", 165cm = 64.96". That's what comes of using the computer at work with an unfamiliar keyboard and OS, while making sure it's not too obvious that I'm slacking off. 😳
Posted : 21/08/2013 7:01 pm
Hi, richc, were you able to get the part number?
Posted : 21/08/2013 7:40 pm
