Best way to remove ...
[Closed] Best way to remove a SFN?
17 Users
 Pook
Is it a case of a long bit of wood and a hammer up the steerer tube?
Posted : 28/09/2010 9:55 am
Why do you need to remove it?
Posted : 28/09/2010 9:56 am
Personally, I wouldn't bother. I'd leave it in and put another on top.
If I HAD TO get it out, I'd use a screwdriver to bend the tabs inwards
Posted : 28/09/2010 9:57 am
bang it DOWN
Posted : 28/09/2010 9:59 am
Drill it out? Won't be able to reuse it obviously.
Stop
Posted : 28/09/2010 10:00 am
It's a PITA, especialy if the steerer is internaly tapered, just leave it alone or very paitiently drill it out.
Posted : 28/09/2010 10:03 am
Yeah, Bang it down, personally I wouldn't bother removing it, just bang it down far enough to get a new one above it.
Posted : 28/09/2010 10:05 am
 Pook
It's slowly working loose on rides. That's why I need to remove it. going to replace with a head doctor.
Posted : 28/09/2010 10:30 am
It's slowly working loose on rides means that your stem is not done up tight. The star fangled nut is just meant to apply tension till you clamp the stem in place and the stem holds the whole lot together.
Posted : 28/09/2010 10:47 am
The SFN shouldn't have any load on it while you're riding.
What exactly is working loose ?
Posted : 28/09/2010 10:57 am
What oblique and MTG said.
Posted : 28/09/2010 10:59 am
They are a bastard and a half to get out. Big **** off bench drill and 1" bit.
Posted : 28/09/2010 11:04 am
or just anything long enough to push it out the bottom of the steerer tube and a few taps with a mallet..
Posted : 28/09/2010 11:07 am
Old piece of copper plumbing pipe and a mallet - knock it down through the base of the steerer.
HedDoctor 🙄 never managed to get one of those stupid things to work properly
Posted : 28/09/2010 12:03 pm
 Ewan
Don't do this on long travel forks - they are normally sufficiently tapered inside the steeer tube that if you try this you'll split the steer tube. Just tap it down far enough that you can fit a new one.
Posted : 28/09/2010 12:05 pm
Remember the tensioners that cane with FSA headsets? Can't remember what they are called. I love them and they really work for me but most hate them. Prob same for Head Doctor.
Posted : 28/09/2010 12:07 pm
Errr, no, not totally correct.
The SFN should fit tight on it's own and not move. It's function is not to 'apply tension' but to be solid enough for the top bolt to take the play out of headset bearings and no more.
Posted : 28/09/2010 12:12 pm
Yes, I always thought that it was to preload the bearings??
Posted : 28/09/2010 12:14 pm
Use smallish drill to drill out the litle silver bit that connects the two "star" bits that grab the steerer. You might need a little screwdriver to push the bit of alloy out from between them as the drilling will loosen it and it'll just spin round with the drill at the end.
Then you should have two separate star bits in the tube. You should be able to flip each one around enough to just pull the out with pliers or something.
Posted : 28/09/2010 12:15 pm
yep then when you have applied the preload (which is via the stem to the headset), you lock the stem in position using the stem clamp bolts and this then retains/fixed the preload position you achieved.
once you have bolted up the stem, you could remove the top cap and bolt and it would have no effect on the headset adjustment....
Unless your stem is not done up properly and it slips...
Posted : 28/09/2010 4:55 pm
