Best HD for a Synol...
Best HD for a Synology DS214play?
9 Users
 bfw
I have a DS214play that is fitted with a pair of RAID1 2TB WD Red HD's. Another one is on its way out, but I fancy a pair of 4TB drives and increase the storage. Should I just buy 2x 4TB WD Red's or is there something else I should buy?
Any thoughts or advice would be appreciated.
Posted : 24/08/2022 12:37 pm
 mert
https://www.backblaze.com/
They do some reporting on most (and least) reliable drives. I have a look in there on the rare occasion i have a drive fail.
Posted : 24/08/2022 3:38 pm
WD Red do seem to be the default recommendation, because supposedly Reds are optimised for NAS use.
If you wanted to go really wild you could consider SSDs; again, WD Red are the most widely recommended, but at £230ish per 2TB, quite a bit more spendy. Different setup, but I went with 2x Crucial MX500 for mine recently. No complaints yet (it's only been a week, mind)
Posted : 24/08/2022 3:40 pm
I'm running Seagate IronWolf drives in both my Synology NAS
Posted : 24/08/2022 3:54 pm
Backblaze reports +1
When I put my DS1520 together I wanted Hitachi drives. I ended up with Toshiba 10TB N300s. They’ve been fine for the past couple of years.
WD have been a bit hit and miss for me in a previous DS.
My other DS. An old 4-bay one. That has a mix of ironwolf and Red.
Posted : 24/08/2022 4:42 pm
The performance/responsiveness difference between the 2014 NAS and the 2020 NAS is marked. Perhaps consider a NAS with SHR and enjoy a bit more zip?
I use the old one to backup select content on the new one.
Posted : 24/08/2022 4:46 pm
I've used both Ironwolf and Red.  Both seem fine.  I tend to mix them if I'm replacing them at the same time, just because
Posted : 24/08/2022 4:55 pm
RAID1, why care. That's the point of it. Whack in whatever is cheapest.
Posted : 24/08/2022 8:06 pm
Agreed.. If you can 'hot swap' a suspected duff drive and the array gets rebuilt .. Why pay more?
Posted : 24/08/2022 8:37 pm
 mert
Because the drives that fail "regularly" cost almost the same as those that don't?
And i don't like spending money...
Posted : 24/08/2022 10:39 pm
I use 6tb WD red's in my NAS..... I'd also consider the equivalent from seagate, but the WDs re always a little cheaper. I've had one DOA, but otherwise, nothing to report.
Posted : 25/08/2022 1:57 am
