BELKIN WIRELESS G R...
[Closed] BELKIN WIRELESS G ROUTER SET UP HELP PLEASE
4 Users
HIive just bought the above but for the love of god after 2 hours i still cannot get this thing to work ive gne threw the set up time and time again,but with no luck ive taken my firewall of still no go any help here please?
Posted : 08/11/2009 9:20 pm
 LMT
Mine just plugged in and worked, have you tried entering routersetup in the web address bar on your browser to access the router??
Also initial setup you have to use the ethiernet cable.
Posted : 08/11/2009 9:24 pm
no ive not done that lol
Posted : 08/11/2009 9:26 pm
mollski whats the problem exactly? no internet?
can you access the browser?
Posted : 08/11/2009 9:27 pm
no ive got net threw ethernet cable i wanted to get my 2 laptops wireless i go threw the cd and its says done but when i unplug the cable from my laptop i lose the net??
Posted : 08/11/2009 9:32 pm
ru using xp?
Posted : 08/11/2009 9:33 pm
no vista on my laptop and xp on my netbook
Posted : 08/11/2009 9:36 pm
Sounds like if its working on the network cable and not wifi then your machine is not being leased an ip address for wireless to get on the network from the router. could be many things...
Drop the network cable into the xp machine.
click the windows '[b]start[/b]' button then the '[b]run[/b]' option on the start menu and type in the run dialog box:
[b]ipconfig[/b]
hit return on the keyboard.
you should see an ip address. something like:
[b]ip address.........:192.168.1.2 [/b]
or similar.
whatever it is listed as type this into internet explorer and hit return (as if it was a web site - but without the http://). you should then get a username and password box. Usually username is:
[b]admin
[/b]
password is:
whatever you have set it as or the default one in the manual.
from here it should take you to the wizard for the router. set up WPA encryption. Better way to go than the CD.
Then once done double click on the wireless icons on the bottom right toolbar and view wireless networks and connect with your new encrypted password setup in the wizard.
also make sure wireless is not turned off on the laptops (a switch or sometimes a button. easily done)
Posted : 08/11/2009 9:49 pm
you are a star many thanks for that going to try it now thanks
Posted : 08/11/2009 9:57 pm
a pleasure mollski
Posted : 08/11/2009 10:03 pm
got the net book up and running its on xp no go with vista 😳
Posted : 08/11/2009 10:25 pm
did you get vista running mollski? I went to bed and missed your last message!
Posted : 09/11/2009 5:44 pm
no sorry 😥
Posted : 09/11/2009 9:17 pm
mollski,
Email me if you like. My email address is on my profile. If you do, let me know what problem(s) you are having with vista beforehand. I can see what I can do to help.
Posted : 10/11/2009 8:11 pm
hi im sorry how do i find your email
Posted : 10/11/2009 9:14 pm
my username on here:
@googlemail.com
Posted : 10/11/2009 9:55 pm
OK WILL MAIL YOU TOMORROW THANKS AGAIN
Posted : 10/11/2009 10:16 pm
 Mof
I initially had trouble getting mine to work so resorted to the Belkin phone helpline which proved very useful and quick despite the Indian speaking accent the helper had.
Posted : 10/11/2009 10:19 pm
ok mollski
Posted : 10/11/2009 10:30 pm
