Beer trick - how ca...
[Closed] Beer trick - how can recreate this?
Full bottle of beer inverted in a glass with no top on. No beer flows until you lift the bottle
[url= https://c1.staticflickr.com/5/4227/34640895022_4573662b24_c.jp g" target="_blank">https://c1.staticflickr.com/5/4227/34640895022_4573662b24_c.jp g"/> [/img][/url][url= https://flic.kr/p/UM6DdJ ]BeerTrick[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
Posted : 21/05/2017 7:13 pm
That's going to be a terrible pour.
Completely the wrong shape of glass.
Posted : 21/05/2017 7:19 pm
An upside down glass on a bottle, hold them together and invert it.
Or am I missing the 'trick' bit?
Posted : 21/05/2017 7:31 pm
While I'm not obsessive about what glass my beer gets served in, I only insist that it stays in the glass until I get it to my mouth, there's something about that one that doesn't look 'right' somehow.
My now regular drinking place has heavy glass tankards, and I now insist on having those, unless they've all been used.
Great for carrying two pints in one hand.
Posted : 21/05/2017 8:14 pm
[i]An upside down glass on a bottle, hold them together and invert it.[/i]
Easy to say, now post a video where it actually works. The bottle top to glass bottom seal is difficult to achieve. Try it.
Yes, wrong glass but the correct Duval glasses I have do not lend themselves to this trick, especially if it doesn't go perfectly.
Posted : 21/05/2017 8:21 pm
Well, yeah, I thought that was pretty obvious?
A funner trick is to do it on a table with someone's pint glass and a beer mat. Then, whip out the beer mat...
If I'm not mistaken that's a bottle of Duvel, and the Belgians are [i]very[/i] particular about their beer being in the right glass. Holidaying in Brussels I once had one in a glass that wouldn't stand up on its own and came with its own little "test tube holder" type stand to prop it up in. IIRC the Duvel one is a short-stemmed glass a bit like a brandy snifter only with a flared mouth (similar to the Stella ones that crop up here occasionally).
Posted : 21/05/2017 8:22 pm
That sounds like kwak. glass very similar to mini yard of ale?
Posted : 21/05/2017 8:25 pm
 joat
Seriously...?
With your history.
Get a responsible adult to pour it for you, drink it whilst sitting down and don't get up 'til you're sober.
Posted : 21/05/2017 8:28 pm
 km79
Check trick number 2
Posted : 21/05/2017 8:35 pm
Start with a decent sized bottle of beer ๐Ÿ™‚ That's just about enough to entertain a mouse or perhaps a hedgehog at best.
Posted : 21/05/2017 8:42 pm
It easy to achieve if the bottle is already empty and thats a picture of your washing up ๐Ÿ™‚
Posted : 21/05/2017 8:49 pm
wipe a wet finger around the rim of the bottle to aid the seal, then put the upturned glass on it.
Posted : 21/05/2017 8:51 pm
I'm also guessing that it's not just the seal but that as the beer tries to come out of the bottle, it's leaving a vacuum behind in the upturned bottom that then resists the beer coming out.
Posted : 21/05/2017 9:52 pm
easier with water as it's not at all fizzy - with beer you'll need to invert carefully so it doesn't froth and blow the seal
Posted : 21/05/2017 10:28 pm
beer lolly? freeze it and wait
(might not be thought through fully)
Posted : 21/05/2017 10:35 pm
The next trick is to half-pour the beer then dunk the bottle neck into it so that the foam gets sucked back into the bottle. Probably frowned upon by Belgians though.
Posted : 22/05/2017 9:06 am
That sounds about right, aye.
Posted : 22/05/2017 9:27 am
Start with a decent sized bottle of beer That's just about enough to entertain a mouse or perhaps a hedgehog at best.
I've made this mistake before. Duvel is 8% if I remember, not to be taken lightly!
Posted : 22/05/2017 10:08 am
Sort of related question. With "live" beers like Duvel, where they contain brewing sediment, do you pour carefully leaving the sediment in the bottom of the bottle with a little bit of beer, pour carefully most of the beer, then swill the small remainder to loosen the sediment and then pour into your drink, or something else?
I know with UK bottle conditioned beers that you're supposed to leave the sediment in the bottle, but foreign beers??
Posted : 22/05/2017 10:28 am
 sbob
You don't pour all the beer at once.
Enjoy the clear beer first then end up with all the sedimentary goodness to finish.
Posted : 22/05/2017 11:21 am
sbob - Member
Shits to follow?
Posted : 22/05/2017 12:20 pm
 sbob
You don't get the shits from beer sediment.
One of my favourite brewers doesn't use any finings so a lot of his stuff is cloudy, still all good.
https://bexarcountybrewery.com/
Peterborough's only redeeming feature.
Posted : 22/05/2017 12:30 pm
Coopers catchphrase used to be "cloudy but fine"
Posted : 22/05/2017 3:38 pm
