Looking for some powerful AA batterys and charger any brands I should be looking at ?
Thanks
Ansmann is all you need to know for batteries and a charger
The best bar none, have a look here
[url= http://www.tantronics.co.uk/acatalog/Ansmann.html ]Battery[/url]
The best disposable batteries are Energizer Lithium.
They are not rechargable and are expensive, but very good.
Not sure if this helps..........
Highly recommended charger [url= http://www.batterylogic.co.uk/technoline/technoline-BL700.asp ]here[/url]
possible word of caution - seem to recall a post sometime back on here about some lights (assumption) not taking reusables - they are sometimes a slightly bigger diameter and if fit is tight- i thought boll@x until went and checked with my tesco cheapie - waits for an expert
Not an expert but these are enough for what I need (2500mha, 1.5v AA's) - http://www.strikalite.co.uk/prodcat_type/18/ALL/0/NiMH_Batteries.html
As antigee mentions watch for the thicker/greater diameter when putting in torches. They will fit with some grinding/filing work to the inside of the torch though.
Looking for them for game controllers, question if I have a NIMH charger already (Uniross) would that charge a new set of batterys ?
I'd guess so. If thats the case see -
http://www.amazon.co.uk/Uniross-2700mAh-Rechargeable-Battery-Ni-Mh/dp/B000IZJ39Q
If they are two big..(tesco style) take the plastic cover off and replace with a cover of parcel tape, it's the right width and does the job, slides in sweet 😉
+1 for the Technoline charger in nockmeister's post... Vapextech rechargeables here too off of that there eBay.
