Ballpark figure for...
[Closed] Ballpark figure for a dormer window
A wee bit help chaps.  I am doing a load of work on the flat and it looks like we will have a bit of money to spare.  There is space and we would get permission to put a dormer window in.  Has to be wooden sash and case and the last similar window I had cost nearly £2000 ( double glazed heritage spec etc etc)  the dormer would be easy to fit in that roof access is good and there is a parapet so no rope work needed.  I'm thinking total cost for a single window dormer about 5ft wide using a heritage spec double glazed single sash and case would be about £5000.  Is that in the right ballpark?  thats assuming paying for all the exterior work but doing all the interior work myself so no interior finish required
Posted : 20/03/2018 7:34 pm
That is about what I paid, including leadwork.
£700 scaffold - to 4th floor.
Its about 2.2m wide and goes to 2.1 high
It was 600 for the carpentry and 245 for wood, basically a stud frame and ply sides/ roof.
Then 2k for it all to be leaded into the existing roof .
1k for the window, hardwood small panes was 1400 wide 700 high, 3 panels two openers and a middle one.
Then  about 500 to insulate and board it. 140 plastering and some electrics for reasons.
Posted : 20/03/2018 8:06 pm
Someone will have to go on the roof so probs scaffolding needed, to do the flashing and whatever external finish the dormer will have.
Posted : 20/03/2018 8:16 pm
No scaffolding needed at all.there is a flat roof above / behind the pitched roof with easy access and a 2 ft wide parapet gutter in front/ below.  I grow plants and sunbathe out on the roof.
sounds like tho It will be a bit more than £5000 tho as the actual window will be a lot more than yours and will be 2m high and 1.7 m wide and I will need to have a lead apron in front of the window as the rest of the guttering is lead.
Ta
Posted : 20/03/2018 8:49 pm
Mine is covered in lead, top sides etc, that's a lot of expense 2k, when it could be done in slates or whatever.
Posted : 21/03/2018 5:42 pm
How high is the parapet & how far back from there to where the work needs to take place/access made?
May need some form of fall arrest/work restraint. Just because you go up there to sunbathe doesn’t mean a contractor can ignore WaHR.
Posted : 22/03/2018 10:15 am
