Attaching a rear vi...
Attaching a rear view mirror to a windscreen with no bracket?
Our motorhome is new shape Movano(Pug Boxer) and I want to fit a rear view mirror as it doesn't have one (it was originally a van with a bulkhead prior to conversion).ย
The windscreen is just glass, there is no bracket inside the screen so I cannot raid the PSA parts bin and just fit a standard mirror from Ducato/Boxer/Relay.
Has anyone got any ideas on how to fit a rear view mirror? I thought about a suction cup like for satnav but the heat/cold can affect them. I suppose that a glued-on bracket will suffer the same problem.
Posted : 27/03/2026 3:30 pm
You can get special double-sided pads specifically for this purpose.
Edit - a very quick search found these...
Posted : 27/03/2026 3:33 pm
Years ago on a kit car I tried one that had a mesh pad and some special glue to attach it to the windscreen.
It was crap.
I got a small suction cup one instead which was much better.
This was almost 30 years ago mind, so tech may have improved since then.
Posted : 27/03/2026 5:13 pm
Fr fr
Posted : 27/03/2026 5:36 pm
Halfords have both stick on and suction mirrors. Could be worth a look.
https://www.halfords.com/motoring/car-accessories/interior-car-accessories/?_gl=1*e8t984*_up*MQ..*_ga*MTU1MTg4OTkyNy4xNzc0NjQxMDE0*_ga_VK44BRER97*czE3NzQ2NDEwMTQkbzEkZzAkdDE3NzQ2NDEwMTQkajYwJGwwJGgw&fq=Product+Type%3A%22Interior+Lights+%26+Mirrors%22
Don't forget STW and Cycling UK members get a Halfords discount ๐Ÿ˜‰
Posted : 27/03/2026 7:53 pm
Thanks all
I was clearly searching for the wrong thing
Posted : 27/03/2026 8:28 pm
On 2nd thoughts I could get a reverse camera to attach to the mirror but it would need to handle the extra weight....
Posted : 27/03/2026 8:29 pm
Posted : 27/03/2026 8:59 pm
I just got a suction one from Halfords....it's fallen off a couple of times in 4 years, on v sunny days. It works fine...just make sure the screen isn't greasy
Posted : 27/03/2026 9:08 pm
Posted by: jeffl
It was crap.
I used this type to hold on a pretty heavy mirror with electric gubbins in. The first one failed after 6 months. The second attempt was still going after 5 years.
I concluded I did something wrong the first time.
Posted : 27/03/2026 10:41 pm
