Are all micro usb l...
[Closed] Are all micro usb leads created equally ?
Only asking as my Nexus 5 charges quicker on different leads ?
are they rated to a certain charge rate ?
Posted : 14/05/2015 8:54 pm
"no, they aren't" is the short answer. The long answer is a bit complicated.
Simplifying a little, there's a 'fast charge' wiring which will, well, charge faster on devices designed for it, and considerably slower / not at all on ones that aren't.
Posted : 14/05/2015 8:57 pm
Unidirectional deoxygenated copper I expect.
Thank you ๐Ÿ™‚
Posted : 14/05/2015 8:58 pm
Longer leads and/or thinner gauge wire will cause a voltage drop which will slow charging down.
Posted : 14/05/2015 9:03 pm
I've had the same experience - funnily, I only ever buy dirt cheap leads and some obviously do have whatever special unicorn hair needs to be inside
Check out the Ampere app, quite interesting in a spoddy way
Posted : 14/05/2015 9:07 pm
Bimbler , thanks for the app , works a treat ๐Ÿ™‚ ... ive got cables that vary from 140ma right upto 900ma !
thanks again
Posted : 14/05/2015 9:21 pm
thanks bimbler - though i had to use a different app
Posted : 14/05/2015 9:25 pm
