Anyone repaired a t...
[Closed] Anyone repaired a top box?
[#10188407]
Rather foolishly I cracked the lid of my top box on a carpark barrier. Crack isn't massive (100mm) and has been waterproofed with gaffer tape as a temporary measure. Was thinking that I could repair it with fibreglass.
Has anyone tried this?
PS. I am a dick.
Posted : 24/08/2018 7:02 pm
Soldering iron.... That's all you need.  Just melt it back together.
Works on motorbike fairings as well.
Posted : 24/08/2018 7:04 pm
Will try that to stop the crack propogating. Got a piece the size of a 50p missing though.
Posted : 24/08/2018 7:15 pm
plumbers glue for grey plastic works on some top boxes, chemical soldering iron.
Posted : 24/08/2018 7:16 pm
I'd probably look at plastic bumper repair stuff
Posted : 24/08/2018 7:44 pm
Get some alu sheet, maybe a cut up drink can and glue it inside the box fixed with a few pop rivets. Worked for my bike box after Air France wrecked it and bought me a new one.
Posted : 24/08/2018 7:55 pm
How about drill holes and "stitch" it together with little cable ties?
Posted : 25/08/2018 9:39 am
Get some High Speed Tape (think thick aluminium sellotape!) - used on aircraft as a temporary fix.
Posted : 25/08/2018 6:54 pm
A few layers of fibreglass on the inside would be very easy, if you are fussy you could show it a little filler and rattle can paint if it's a gloss finish.
Posted : 25/08/2018 7:20 pm
You may find fibre glass doesn't stick if it's Polly.
I'd use a poly adhesive such as tiger seal on the inside and glue a patch in
Posted : 25/08/2018 7:51 pm
whatever you do its gonna look rubbish and disintegrate next week
buy a bigger car and put it all inside
Posted : 25/08/2018 10:58 pm
Welded up using a soldering iron and a bit of plant pot.
Don't care if it looks like shit as long as it holds and keeps the water out.
Posted : 01/09/2018 4:28 pm
Like it. Good result. Well done. Stick it to the naysayers.
Posted : 01/09/2018 8:41 pm
I did this once and just ran a bead of sikaflex polyurethane sealant down the underside of the split. Worked fine.
Posted : 01/09/2018 11:03 pm
Welded up the inside too (nearly choking on the fumes). There's quite a lot of plant pot fused to it now.
Posted : 01/09/2018 11:29 pm
Looks good, not really noticeable if you didn't know. Top job.
Posted : 01/09/2018 11:43 pm
Soldering iron weld and cover with your favorite MBUK sticker...
Posted : 02/09/2018 9:10 am
