I want to set the altitude on my suunto watch
grid refs are SE 37930 36412 (WGS84)
thanks
Ordnance Survey get a map and use the contour lines?
find your house on google earth, it should show the elevation
322ft
About 97m.
[Norn Iron voice]
I know where you live!
[/Norn Iron voice]
99m
Whats that boozer like?
boozer poor but organic ale at £1.40/pint is ok
do you have a Garmin device of any variety?
i do but i am not sure how accurately it has been caliberated
go to a beach, set it to zero.
Type your postcode into the following ordnance survey site and zoom in on the map until you can read the contour lines....
http://www.ordnancesurvey.co.uk/oswebsite/
Google Earth is your best bet.
If you use a barometric altimeter you can get the local pressure setting from a nearby airport. Remember that at your elevation and considering the colder weather you might want to subtract about 20 feet.
Dont use a sat nav. My phone came with Copilot installed and it claims that bournemouth prom is 110 feet above sea level
you'll need to get used to checking the height of a point on an OS map and resetting as the weather changes, since pressure altimeters rely on a datum being accurately set. not that often, but certainly from day to day if you're going to use it to aid your nav.
surface pressure (QNH) can vary widely: typically 970mb to 1030mb at sea level are not uncommon, with 1013 being a standard day. each mb makes 30ft of difference
QNH is sea level pressure, QFE is surface pressure.
I've seen pressure changes 4 times in an hour (that works out at 120ft) so you need to change it more than just daily if you want to accurately measure altitude.
A map
[pedant]
QNH isn't sea level pressure, it's the QFE mathematically corrected to sea level assuming standard conditions. QNF is the QFE mathematically reduced using actual conditions.
[/pedant]
Flaperon, QSY off to pprune, where people may care.
As above - you'll need to constantly reset the altitude. On a typical days spring or autumn walking in the Scottish Highlands, I've had to do this up to 6 times. However, if you know you're altitude and it changes while you're stationary (e.g. overnight) this can help identify incoming weather.
Look on an OS map and see if there is a BM (Bench Mark) near you?
I used Google Earth and found I am at 197 m (646 ft). Who lives the highest?
Or an earthquake...
Spesh99 - are you my neighbour?
Don't think so I'm in Balerno in Edinburgh. I almost live in the Pentland Hills.
I've just checked and my house starts at ground level and goes up about 30ft.
Spesh99 - Member
Spesh99 - are you my neighbour?Don't think so I'm in Balerno in Edinburgh. I almost live in the Pentland Hills.
Gulp! [i]Where[/i] in Balerno?
Gulp! Where in Balerno?
Why where are you? Click my name and email me if you wanna know where I am.
[i]Who lives the highest?[/i]
I live in Holland so I'm willing to bet it's not me.
