I don't usually follow it - but a rain delay with Yorks 1 run away from a crucial bonus point with 1 wkt remaining - that's tension!
Somerset will have it wrapped up by close of play.
Notts needing 480 with 3 down - Only the weather gods can save them.
I guess that depends on how long the rain delay goes on for and what happens when Yorkshire walk back out - they didn't do too well straight after lunch.
I fancy Zummerset under normal circumstances, not enough time left at Lords on a flat pitch to get a result.
But...... it won't be normal circumstances, it'll be declaration cricket to contrive to produce a result. So could go either way at this stage.
One of the Middx batters to get 100 in 50 odd balls though, might be worth a bet.
First hurdle cleared...
Yup, tuned in here
Saw some the other day, the crowd seemed to consist of no one ๐
Now we have got past 350, the sledgehammers have come out ๐
๐ฏ dare we believe?
Depends if Middlesex carry on rolling over...
Somerset still in with a chance if its a draw at Lords!!
Reckon it's Yoooooorkshires to lose now though.
Yeah, I think it would need a weather intervention now if it's to be anyone's but Yorkshire's (from the BBC updates, it seems every other ball is a potential wicket ATM).
Bit different this morning.......
New ball in 25 overs, by which time the lead will be ca 80-90 at this rate. That's Yorkshire's last chance to win the game 'properly'; if they can't get Middx cheaply with it then they're relying on Middx to set them a gettable target and contrive a finish.
I'm sticking with Zummerset, be fab to see them win it for the first time*
* incredible really, but shows the influence of weather in winning the county champs.
Given that a draw suits neither side, I suspect that the captains will have a discussion, should Middlesex still be batting well into the afternoon.
Meanwhile, Lancs are in the middle of a Lancs-up.
So frustrating - at 2-2 yesterday it seemed it was all sewn up but things have gone to pot. And I doubt the conditions will be helping Yorkshire today either.
Still - what a way to end a season!
So frustrating - at 2-2 yesterday it seemed it was all sewn up but things have gone to pot. And I doubt the conditions will be helping Yorkshire today either.Still - what a way to end a season!
I'm not so sure - had Yorkshire taken a couple of early wickets then Middlesex would've shut up shop, making it harder to take all ten. As it is, we might see a challenging declaration which Yorkshire will have to go for. It should be a cracking finish.
Declaration bowling at Lords... I wonder what score has been agreed?
Well the way the pitch has played today, 6 an over is do-able. So is a crushing defeat.
That's an incredibly generous declaration - bear in mind that Middlesex will need to set attacking fields in order to win.
unlikely to bowl a team out in 40 overs even with an attacking field.
I think with how crazy this match has been so far, anything could happen.
10 wickets in 35 overs
9 to go
Run rate going up...
Intriguing. I hope it's close but if not (say Yorkshire lose 6 wickets quickly) does the mentality of 'well if we can't win we don't want you to either' then come into play. Or is it better to win or die trying?
I know in the end the latter is the sane choice - if you can't win who cares who does. But there's that mentality in sport that means you hate to see someone else succeed at your expense.
And another down
Getting tighter
apart from the runs in the first few overs it's been very tight from middlesex.
3 down
rr upto 7
yorkshire are going to be a 100 runs short scoring at this rate.
7 down 65 needed from 6 swung to middlesex now !
who would be a somerset fan!
8 down
๐
won with a hat trick !
What a finish!
Wow. You have to feel a bit sorry for Somerset.
