Anyone fixed a phon...
[Closed] Anyone fixed a phone GPS?
6 Users
My phone (htc one) GPS is completely dead. Complete reboot hasn't helped, so probably a hardware issue? I've seen a few write-ups of people opening the phones up to tinker with the connection to the GPS antenna, worth a go?
It's a sealed unit so wondering if springing it open and messing about with it might prove to be a waste of time.
Posted : 01/09/2016 10:14 am
Probably of no help at all, but when I had this on a Galaxy SIII, a phone with a removable back cover, taking the cover off and tightening all the little screws holding the innards together (some of which were loose) fixed it.
Posted : 01/09/2016 10:16 am
Seems to be a fairly common issue on samsung galaxies. Mine occasionally loses the signal but a little squeeze where the antenna is and its back. One day I'll open it up for a proper fix but its not that bad yet. There's a few write ups online for a repair. Might be similar for your HTC.
Posted : 01/09/2016 10:20 am
Keep searching on the internet. There where similar sounding problems with iPhone phone signal antennas. As these where located naturally around the edge of the phone dropping the phone had a habbit of damaging the connection.
I had an issue with old 4S wifi which was a know issue of bad chips, Apple said it wasn't economically repairable and phone was 4 years old so its just a rarely used backup now.
As for opening it you could but connection may be soldered and thus not easily repairable.
Posted : 01/09/2016 10:45 am
unless you have a soldering iron, in which case it's a 2sec fix to reflow the connection.
Posted : 01/09/2016 1:43 pm
Soldering. The connections are tiny in general. Not something I'd try unless I was prepared to write the phone off.
Built my first computer from a box of bits in the 1970's so familiar enough with soldering.
Posted : 01/09/2016 2:26 pm
Have you installed any new apps? I tried installing "OS Locate" to my HTC one recently. It contains a bug and prevents GPS from working in other apps such as Google.maps.uninstalling OS locate fixed things instantly.
Posted : 01/09/2016 3:44 pm
