fell out with my trusty acer the other day,now the screen needs replacing!!! anyone,thinking bout using it as a desktop and removing the screen/lid as battery knackered anyway and using a conventional pc monitor,would it work without the lid? what is the name of the cble i require-the laptop has a 3x5 pin connection with the centre row offset,anyone help please?
If your model has a VGA port (it should do), you should have no problems removing the screen/lid and just using a monitor connected to that. It's very difficult to connect anything to the laptop screen socket, for various reasons that I won't go into.
I had a dell laptop that I took the screen off and just ran off VGA when I needed to, worked fine.
Halfway there, been nursing it along though - it will snap the last bit of plastic soon.....
This,
Is that.
Laptop should run happily just with an external screen. You might need to enable it once it's connected, usually Fn and one of the F-keys, look for a little blue picture of a TV screen on your keyboard somewhere around F5.
thanks all-time to shop for a monitor,and place a wanted ad
