As above, really.
IE?
Hmm. My browser has been crashing every time I visit 123reg.com but I've had STW open every attempt too... Will close STW for a mo, try again and let you know if it works...
EDIT; no, 123reg.com is definitely the culprit in my case...
i knew [i]someone[/i] must still be using explorer. 😀
chrome FTW.
Switched to Chrome about a month ago - much, much better.
Tried installing Chrome on the laptop (running Vista) three or four times, and it just plain don't work. Constant crashing.
I knew someone was still running vista...
LOL
I'm still running Vista
don't go anywhere near IE though 😉
Firefox and/or Safari here
You run a Microsoft powered computer?
How frightfully common of you CaptainFlashheart.
Go to Help -> About (or Press ALT+H, and then click About Internet Explorer). Note the exact version number, then type it in here - knowing that information somebody can probably advise you with some accuracy.
It's called Internet Exploder for a reason. (Many) other alternatives are available - I suggest you use one of those...
Several websites I've used get upset about a 64 bit browser. Singletrack doesn't crash (Tescos does) but it seriously messes up the formating. It seems to pay to stick with a 32 bit browser.
Yup, me at work (IE8 on a local authority laced up number, no chance of anything else loaded on it. don't panic I'm on my lunch). It doesn't always move to the next page and comes up with a fault. I get around it by opening new tabs...
bit of a pita though.
