Anybody had a go at...
Anybody had a go at re-enameling / painting their bath?
[#12638843]
Doing a quick bathroom freshen up and the old cast iron bath is in a bit of a mess. I'm thinking on giving it a sand and repainting it - roller/brush, not spray paint. A professional re-paint is around £300-£600 so not what we're looking to do. In all likelihood the bath will be torn out in a few years time so this needs to be a DIY job. Am I going to regret this choice, any tips appreciated.
Posted : 04/12/2022 1:20 pm
Yeah. It was better than what we started with but not perfect. Suspect better preparation would have improved things.
Posted : 04/12/2022 1:27 pm
We didn't bother. An acrylic bath doesn't lose the heat in the bath water as quickly. You can get lots of bath styles and 10 years+ guarantees. Choose a well-made one, particularly if free-standing, to avoid flex
Posted : 04/12/2022 1:33 pm
Ours picked up a chip inside. Didn't want to bin it and couldn't be bothered to paint the whole thing so I sanded and painted an area. It's noticeable but totally functional. Hasn't deteriorated in the five years or so since I did it. As long as you don't need it to be pristine a DIY job should be fine and sounds sensible
Posted : 04/12/2022 2:25 pm
Ours had a rust blister/void - filled it with Milliput white epoxy, been fine since.
Posted : 04/12/2022 3:18 pm
I managed to strip the enamel from mine somewhat accidentally when I filled it with citric acid to de-rust some bike parts 😀
Fortunately we were replacing it anyway, but I was surprised it was so effective.
You can do spot repairs. Coatings of the type mentioned above. There are probably professionals out there who'll do a good colour match for you. A full re-enamel is probably not worth it. When we looked they didn't even guarantee it wouldn't be destroyed.
We don't tend to use the bath so replaced it with a modern one. They look nice but we found the cast iron one a pain. A proper shower was better. And a cheaper batch worked better - cast iron is a massive heat sink so the water going in had to be scolding to get the thing tepid.
Posted : 04/12/2022 6:05 pm
My mum spent ages reemameling the 100 year old one in our house as a kid.
It looked a lot of work. It was better, but not perfect. It lasted for years until it got swapped for a shower.
Posted : 05/12/2022 1:29 pm
Used a Tubby re enameling kit a few years back and it turned out better than I expected. As with most things it's all in the prep. You won't achieve a perfectly smooth finish (slightly orange peely) but perfectly acceptable.
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://tubbydiy.com/&ved=2ahUKEwiEyOKwvuL7AhUJZsAKHVOMBVIQFnoECA0QAQ&usg=AOvVaw2Tej_QrkptZQVs9XvPQdzZ
Posted : 05/12/2022 1:37 pm
