Any way of telling ...
[Closed] Any way of telling if a sent Emails been read the other end or not ?
15 Users
other than requesting a recipt , is there any other way i can check if my emails have been read or opened ??
running win 7 if that helps ?
cheers
Posted : 10/07/2010 10:01 am
hack their account?
Posted : 10/07/2010 10:02 am
no - would be a major privacy issue if your recipient's mail client were to go around sending any information about it's status to other parties wouldn't it?
Read receipt requests are all you have, and of course can be declined by the recipient too.
Posted : 10/07/2010 10:05 am
Stoner - Member
thought id ask anyway ..
cheers
Posted : 10/07/2010 10:08 am
Reliably? No.
Read receipts are fairly hit and miss, as it's not a 'standard' and relies on the recipient end of the transaction honouring the request (and often, when it does work it prompts the user to opt out of sending the response anyway).
The only thing a receipt will tell you is that it's been opened if you get one. It doesn't tell you if it's been read (cos the other person could have opened it and closed it again without reading), and the absence of a receipt doesn't tell you that it hasn't (because there's a dozen other reasons why this might happen).
The only sure fire way of knowing if someone's read something is to ask them.
Or you can be sneaky and embed "web bugs" in an HTML email.
Basically you create a 1x1 blank image, give it a unique name, stick it on a server, and include it within the email. Then check the server logs and watch for the image request.
That's what a lot of spam emails do, but might be a bit involved for your needs 😀
Posted : 10/07/2010 11:09 am
 hels
Or you could just stalk the young lady the old fashioned way, by parking outside her house...
Posted : 10/07/2010 11:15 am
 will
Posted : 10/07/2010 11:47 am
Most decent Email clients disable images by default though to stop such spam tactics. Of course the user may still elect to view images or perhaps they have a poor Email client 🙂
Posted : 10/07/2010 12:02 pm
I thought that within Outlook there was a way of retrieving a message that hadn't been open and read by the intended recipient. Not quite what you were asking but could be of use if it's actually possible.
Posted : 10/07/2010 12:23 pm
you can only do that on mail routed through the same exchange server johnny., i.e. within the same company mail system,
Posted : 10/07/2010 12:24 pm
Le voila - works flawlessly.
[url= http://www.didtheyreadit.com/ ]http://www.didtheyreadit.com/[/url]
Posted : 11/07/2010 1:17 pm
 IA
If it matters that much give them a call?
Posted : 11/07/2010 1:45 pm
didtheyreadit is sort of clever in a bandwidth wasting way, they add a bit of code to your email that downloads a big file veeeerrrrrryyyyyy ssllloooooooowwwwwllllyyyyy and they count how much of it is downloaded as the email is open. your sysadmins may not like it.
Posted : 11/07/2010 1:57 pm
this wouldn't work on me as I always use a web based reader and block all inclusions. Also I don't understand why a big inclusion would make any difference - so long as it's unique it could be a single byte and be as effective.
Posted : 11/07/2010 2:52 pm
At my work you can check if an email has been opened. Internal mail only though.
Posted : 11/07/2010 2:54 pm
[url= http://www.oreillynet.com/onlamp/blog/2004/06/more_on_didtheyreaditcom.html ]See what you think[/url]
Posted : 11/07/2010 4:10 pm
sfb - the file is downloaded at 8 bits per second, the download rate is counted so that the server can calculate the time that the message has been viewed for.
http://freedom-to-tinker.com/blog/felten/new-email-spying-tool
Wouldnt work for me either as google apps mail blocks images unless authorised.
Posted : 11/07/2010 4:13 pm
Wouldn't it also give a false positive if you use outlook preview pane?
Posted : 11/07/2010 4:23 pm
in which case it doesn't need to be big 🙂
yes if you're dumb enough to enable images in it 🙁
Posted : 11/07/2010 5:02 pm
what I meant was the sender may think that the recipient had read it - when in fact they had preview pane running with image downloads enabled
Posted : 11/07/2010 6:18 pm
yes, understood - but enabling images in preview [b]is[/b] unwise 🙁
Posted : 11/07/2010 6:49 pm
