Any telephone engin...
[Closed] Any telephone engineers in the house?
Home phone only rings once or twice when anyone calls. BT has tested the line and no fault found. Have tried a different handset and the problem remains. Making outbound calls is no problem. I think that the call is connecting automatically after one or two rings. Guess the problem is somewhere in the internal wiring?
Posted : 20/12/2012 11:07 am
Have you tried it on the test socket?
Posted : 20/12/2012 11:08 am
have you uinplugged all broadband equipment and filters, extensions, so you just have the BT master socket with a phone on it.
also with no phones plugged in what happens?
Posted : 20/12/2012 11:18 am
Just because BT can't 'see' a problem, doesn't mean there isn't a problem.
If your socket faceplate has a 'panel gap' across its face, undo the two screws and remove the front half of the socket, there is another socket there. Plug in a previously unused or a neighbours phone without using a broadband filter, and try ringing it.
When it rings and stops, if you pick up immediately is anyone there? If yes, then it is probably a fault. If no, you've got some prankster playing you around.
Posted : 20/12/2012 11:31 am
Does it ring and then stop ringing but the incoming call is still there? Or does it ring and cut off, dropping the call?
Have you tried using a different phone?
Posted : 20/12/2012 12:01 pm
is your fax machine picking up the call ๐Ÿ˜‰
* not helpful i know but i rememebr the 80s/early 90s vaguely watching my parents trying to beat the business fax to the call. ๐Ÿ˜‰
Posted : 20/12/2012 12:42 pm
Have you tested with the phone plugged into another socket? Broadband etc. all working OK?
Posted : 20/12/2012 4:27 pm
