Any stats experts a...
[Closed] Any stats experts around?
5 Users
Morning all
Could anyone tell me the best way of presenting the following outcome data?
I have a set of scores (range of 0 - 10) with a frequency of each score
I believe this is ordinal interval data?
I guess crudest way is using the median?
Is the correct way to plot a normal distribution or even a 'box and wisker plot'? (this is what google threw at me)
You can see what an exciting morning I am having. Hoping to ride later though...
Thx
PS mods feel free to move to chat forum - posted in error
Posted : 09/02/2014 7:34 am
What are you trying to show?
It's only 1-10, simplest would be a bar chart showing number of responses to each. Box and whisker is really for much wider samples of data - showing quartiles and outliers. Neither of which are very relevant in a very finite data set.
Posted : 09/02/2014 8:17 am
Njee is spot on here, a simple graphic will tell you everything you need to know.
Depending on how the data was generated, the median may be irrelevant or completely misleading.
Matt
Posted : 09/02/2014 8:27 am
Thanks for the answers chaps..
Data is actually a set of pain scores (0 = no pain, 10 = bad pain). It is fairly easy to interpret a bar graph of score versus frequency for say all operations. What would be the best way to display it when comparing operations though
e.g. operation 1 (frequency x pain scores) operation 2 (frequency x pain scores) operation 3...
Is it just a case of producing bar graphs for each operation?
Posted : 09/02/2014 3:23 pm
 poly
j3ffo - I've usually found a stacked bar chart lets you see the comparison between the groups and the overall trend. You might find its just a mess once plotted though - in which case individual plots would possibly be better it depends what you are trying to show: Operation 1 is better than operation 2, or operation 1 is better than an average operation etc.
Posted : 09/02/2014 3:39 pm
DO you want the data to discover something, or try and use the data to convince someone else of your wants (generally to fund more research)...
Posted : 09/02/2014 3:47 pm
