Any sparky's i...
[Closed] Any sparky's in the house?
15 Users
Hi, can anyone give me some advise? Just fitted a new 9.5kw electric shower to replace the old one that has never worked in my house. It pops the fuse after about 4 - 5 mins. It has a 30 amp breaker fitted, is that about right? or should it be higher?
Thanks
Mick
Posted : 27/02/2010 8:55 pm
The fuse is specific to the cable size, by upping it you risk the cable overheating and catching fire.
A little Googling suggests you should have 10mm cable with a 45A RCD/RCBO for 9.5kw.
Posted : 27/02/2010 9:01 pm
As above - 9'5 kw is 40 amps so will trip a 30 W breaker and your wiring is probably not big enough for 40 amps anyway
Posted : 27/02/2010 9:22 pm
Give me a call tomorrow Mick, I'll get hold of a breaker for you and have a look at what size cable you have in there.
Posted : 27/02/2010 9:23 pm
I had some works done when I bought my place. The 9.5kw mira sport shower I had fitted was with 10mm cable and a 40w breaker.
I'm not a sparky, but from what you say it appears that the 30w breaker may not be up to the job.
I'd say get it checked out by a pro. ❗
Posted : 27/02/2010 9:30 pm
I dont know about a pro, i'll try Curly68!!! Curly, i didn't want to bother you with it, you must get it all the time aswell! I'll give you a call, think i still have your number. Thanks all!
Posted : 27/02/2010 10:10 pm
As has already been posted, it looks like you have replaced a non operating 8.5KW shower with your new 9.5KW unit.
The current drawn by a 9.5KW shower is 39.6 Amps. The maximun current carrying capacity of a 6mm cable is 34 Amps*. A 10mm cable has a capacity of 45 Amps*.
* both these can be [i]reduced[/i] depending on how the cable is routed!
[b]
Under no circumstance[/b]s should you change the breaker for a 40A version if you have a 6mm cable. I have seen melted cables at 2 properties that I have been to sort out. Not only is it downright dangerous, but, may invalidate your insurance if you have a fire.
Any work carried out in a bathroom must be carried out by a Part P registered sparky, tested, certified and notified to LABC. Additionally, the shower must be protected by a 30mA RCD or RCBO.
Posted : 28/02/2010 10:02 am
Bit too late on this thread - but as 49er says
DO this properly - As mentioned above, a melted cable, if not properly protected at the consumer unit could lead to a fire - which insurance will prob not cover.
Posted : 28/02/2010 10:09 am
Unfortunately, this is the reason that the rest of us have to mess around with getting Part P certification when we do anything to our own properties despite being more than adequately qualified (ie electrical engineers who have to pay an electrician to put a shower in).
Posted : 28/02/2010 11:28 am
Given that you'll be standing in water .I'd get a proper electrician to fit it.
Mess it up and the first person to use the shower could be electrocuted and killed.
Posted : 28/02/2010 12:04 pm
Being a little pedantic here, but its 230Volts these days not 240volts, so it would work out at 41.3Amps.
Posted : 28/02/2010 1:20 pm
we're being robbed of 10 volts. It's an outrage
Posted : 28/02/2010 1:24 pm
[i]we're being robbed of 10 volts. It's a [b]voltrage[/b][/i]!
Posted : 28/02/2010 1:29 pm
Nah, the volts are still there. So in fact, we are getting free volts! 10 or more whole volts for free! Anyhoo, as summed up by 49er_jerry above, run a 10mm cable in if you want to use a 9.5kW shower. Will need to be RCD protected and the work is notifiable under part P. Alternatively, replace the knackered shower with one of the same rating. Such like-for-like replacements are not classed as installation work and as such, are not Part P notifiable and do not need the wiring updating with RCD etc... Probably your cheapest option, all things considered.
Posted : 28/02/2010 1:51 pm
dudie gets it in one. as long as it is a like 4 like then part "p" is not required, but saying that how do you know the installion is correct pre part "p"
electric showers are rated 230~240 volts to allow for the voltage ups and downs but i still find a lot of sites at 251v
if not already fitted an rcd is a must for any appliance in a bathroom
like gas fitters electricans come in all shapes and sizes and i have seen to many bad ones since part "p" for sparkys and safegas (corgi)to make me feel safe at home
Posted : 28/02/2010 2:52 pm
Thanks all, i had no intention of rewiring myself! although it cant be to hard if people on here can do it 😆 had it checked today (thanks curly!) and do indeed need an uprated breaker (wiring within spec)More money!! I only replaced the original 9.5w with one of the same power, so dont quite know how that used to work!
Posted : 28/02/2010 8:53 pm
Very true quote - but rules are rules I suppose.
I am and electrical engineer and have recently re-commissioned 2 132kV -11kV grid transformers and I am currently testing most of the protection on the 11KV ccts feeding B'ham city centre - yet after I replaced my wylex fuse board for an RCB prtected one - I need a spark to check out what I done 😉
Posted : 28/02/2010 9:10 pm
jumping_flea - Member
Yea it is a bit crazy I am a qualified installation electrician ( and ex aircraft electrician) and I can do anything anywhere from factorys to domestic for any company and certify my own work and provide test documentation to prove safe etc
But I am not part P registered so I cannot do my own place 🙄
HTF does that work
BTW the reason you 30a breaker does not trip immediatly is because breakers trip on a logrithmic time curve ie at 40 amps as you say about 5 minutes but at 80 amps about 3 seconds
Please get it done properly electricity is dangerous stuff lets not talk worse case scenario, but if your place burns down due to a electrical fault and it is found that cables were overloaded insurance companys will wriggle like crazy and NOT pay up
Posted : 28/02/2010 9:23 pm
