Any reason not to g...
[Closed] Any reason not to get rid of cold water tank?
Clearing our attic for a conversion and looking at the cold water tank. Have emptied it and discovered the cold water and the toilet run from it. Any reason why I can't just connect these to the mains supply as well? Should I even attempt this myself?
Posted : 17/03/2012 1:20 pm
If there is a water cut you have no water at all stored in your house and the valves in the toilet might not like the extra pressure - but many houses do not have any tanks now and its simple enough to do
Posted : 17/03/2012 1:30 pm
Your cold water tank probably feeds the boiler/hot water, so not as simple as just re-jigging some plumbing.
Posted : 17/03/2012 1:42 pm
As TJ, some taps/shower/valves may not handle mains pressure water.
Posted : 17/03/2012 1:44 pm
It won't feed the boiler / hot water - that would be a separate tank
Posted : 17/03/2012 1:45 pm
we have just had a combi boiler fitted, so don't think the cold water tank is connected to that. The shower was still working after I shut off the supply from the tank so assuming it is connected to the mains.
Posted : 17/03/2012 1:47 pm
IIRC the building regulations changed some years ago and it is no longer compulsory to have a cold water tank. It's handy for flushing the loo in the event of a water cut though ( which is why it was a requirement).
Posted : 17/03/2012 1:49 pm
My boiler is fed from the cold water tank. As far as I know thats normal for a traditional type boiler...big tank for hot and cold water, small tank for central heating header.
But the OP's comment about having a combi-boiler fitted means that it probably is fed from the mains and not the tank.
Posted : 17/03/2012 1:54 pm
Combi boiler is definitely sealed system - not fed from cwt.
Your ball valves in the loo cistern may not be high pressure valve so MAY need changed. You MAY have to change a ap or wo depending on whether they handle the higher pressure but the trouble is usually taps that aren't designed to handle too low a pressure - you should be fine.
Posted : 17/03/2012 1:57 pm
