Any plumbers on?
[Closed] Any plumbers on?
What do i need to plug this hole on my waste pipe?
I'm not sure what used to bung it up, but it is gone and i appear to be showing my neighbours in nasty toilet water!
Posted : 14/09/2014 9:41 am
Something like this
http://www.screwfix.com/p/socket-plug-40mm/34151
Probably £3 at b&q or pop to toolstation/screwfix for change from a quid. They do seem to work their way out over time. Maybe Add some silicone or put a zip tie round the lot
Posted : 14/09/2014 10:00 am
Ugh. I'd shove in a bung wrapped in a plastic bag until I could find something permanent. I've a feeling you're going to need to get a length of whatever pipe was in there, cut it down very short and glue a stop end on it.
Edit: that's the answer, above.
Posted : 14/09/2014 10:01 am
nickjb - Member
Something like this
Thanks. Just been to Wickes and they didn't have any bungs, but i'll fashion something. I rent so the landlord will sort a permanent solution. Now to tell the neighbours downstairs what's been splashing their yard with!
Posted : 14/09/2014 10:58 am
Bit of cling film, job done.
IANAP 😛
Posted : 14/09/2014 9:07 pm
Na.A full can of expanding foam should sort that out. 😉
Posted : 14/09/2014 11:47 pm
