Any hinge experts o...
[Closed] Any hinge experts on here?
[#2608868]
I've checked the usual places but can't find this - is there a hinge that'll take an inset cabinet door (ie. face of closed door flush with face of frame) and allow it to open so the door ends up at 90 degrees but with the inside face of the door sitting about 10mm across the face of the frame? ie. so if it were hinged on the right and you looked at it from the end of the open door you'd be able to see 10mm of frame to the left of the door when it's open.
It'd obviously need some sort of crank/cam arrangement but I can't find anything that looks right.
Posted : 29/03/2011 7:45 am
Not sure where you have checked but try Hafele or Ironmongery Direct.
Posted : 29/03/2011 8:10 am
I'm more of a bracket man.
Posted : 29/03/2011 8:14 am
a cranked flush hinge?
Posted : 29/03/2011 8:16 am
I'm sorry, but it's late and i can't really be bothered to read your inquiry. However I am aware of their work if you have any specific questions.
Posted : 29/03/2011 8:22 am
Nickjb - already looked at both of them.
Rewski - was expecting pix at the very least! [EDIT - thanks alex!]
Stoner - they seem to step the door out from the face of the frame rather than across it
Posted : 29/03/2011 8:27 am
Thats hinge and bracket.
I've got a couple of girl-mates called Mary Hinge and Kelly Smunt.
Posted : 29/03/2011 8:54 am
Sounds like you need a hinge similar to those fitted on kitchen doors. I know they're mostly for lay-on doors, but can you get them for inset doors? When I've looked for specialist hinges in the past, I found [url= http://www.ironmongerydirect.co.uk/Products/Hinges ]Ironmongery Direct[/url] to be quite good. Having said that, I've never come across your type. They have "inset" Blum hinges on their site, but whether this "inset" refers to the door or something else, I'm not sure. Good luck! 🙂
Posted : 29/03/2011 8:58 am
Fair enough 🙂
I suspect you may need this tyle of hinge (although not this exact one)
Although this looks close, but not 90deg:
[url= http://www.cabinet-hinges.com/catalog-product.php?p_ref=18295 ]http://www.cabinet-hinges.com/catalog-product.php?p_ref=18295[/url]
Posted : 29/03/2011 9:28 am
You are needing the door out of the way so you can use a drawer the whole width of the cabinet? This means you cant use any kitchen style hinges 'cos they would get in the way and what you want isn't made.
You might get somewhere with Hafele 362.10.803 and jig it so the hinge passes right through the gable and the pivot is outside of the cabinet.
As has been pointed out hinges are designed NOT to cause the door to hit adjacent furniture when open.
Good luck!
Posted : 29/03/2011 5:59 pm
http://www.woodfit.com/index.php?cPath=114
dont think you will find out mind and if they dont stock it then it doe not exist - local to me if you want something
Posted : 29/03/2011 6:24 pm
