Any electronics whi...
[Closed] Any electronics whizzes in?
3 Users
I've got a faulty pcb in my car heater control. Thanks to the internet I've found the faulty component: An SLD24 ( http://pdf1.alldatasheet.com/datasheet-pdf/view/122722/LITTELFUSE/SLD24-018.html) transient voltage suppressor.
I can probably get a replacement on-line but I need a high street solution as my dash is hanging out and its not an easy job to pop it out again.
Option 1. Just remove the component. This works but I wont have any protection.
Option 2. Bits from maplin. Will this work?:
Four 12v zeners ( http://www.maplin.co.uk/Module.aspx?ModuleNo=19091) connected like this:
--->|->|--|<-|<--- (if that makes sense)
Posted : 28/03/2009 11:05 am
I remember Fords having this prob on 91 escorts.
I just had the board copied.
Are you trying to bypass a module by copying it's circuit on to a board?
Tried the scrapyard?
Posted : 28/03/2009 12:15 pm
If I'm not very mistaken, yes you solution of 4 zens will work fine, assuming you have matched or exceeded the power dissipation requirements.
Posted : 28/03/2009 12:50 pm
