Embarking on a project to remove wallpaper and restore wall to a nice clean/smooth finish in order to paint with emulsion.
Paper is off butbi need to get rid of the paste residue or some I'm told, I have been advised to remove it with a sponge and sugar soap water...its going to take me forever to do this and even then I'm not confident it will all be gone...are there any quicker, easier solutions I should be trying?
I read online to prime with an oil based paint, when I asked at Wicked and B&Q they told me I was stupid!
No in a word. it's all in the prep.
I'd get the walls cleaned and then use a thin emulsion mix to prime them.
Get used to having to do loads of spot filling too....
Just give the walls a clean and filling and sanding then paint with a thin first coat of emulsion. If any stains start showing after it's dried just go over that bit with some stain block or oil primer/undercoat.
You'll never get rid of the wallpaper glue completely - every time you use a water based paint it'll get sticky again. You could try an oil based primer but I'd put up lining paper and paint that.
Thankyou by thin emulsion mix do you mean watered down?
Also stain block...could you kindly link to the type of thing you'd use (wickes or B&Q).
I did think it was clean so filled last might and sanded this morning was very proud of my lovely wall until I usedca damp cloth to wipe it down then this paste seemedcto come from no where, sugar soap has washed the filler away!
Reef what oil based paint? Its a buy to let, if I can get the walls good now will make future maintenance easier, lining paper is probably a bit more work in the long run, I'd like tovtry and getvit right now.
Painting on old paste causes the paint surface to eventually split and will continue to split every time it's painted, it may or may not be noticable depending on how well you wash it down. So if you're a gambling man or not too fussy get walloping - otherwise line it ๐
Lining has the advantage of not showing bashes in the wall so much either if it is buy to let
I'm kind of working on when tenants change over if they mess up the wall filler, sand, paint...like new!
