Any decorators in?
[Closed] Any decorators in?
7 Users
I've got some water damage to a woodchipped room at my Nan's place. The leak was fixed ages ago and it's all dry now. I need to somehow patch the damage with new paper and paint over. Any tips on how to do this? Also, will I need to add a stainblock before the paper?
Thanks 🙂
Posted : 27/01/2017 11:43 am
Cut away all loose paper. Use a blade to get straight lines to make patching in new paper easier. Any oil based paint as in gloss or undercoat will do to go over stains . If bare plaster visible use a watery mix of paper adhesive to seal plaster or it wil grab new paper it you're slow applying it, getting fixed into position.
Posted : 27/01/2017 12:57 pm
Thanks Marin.
So, undercoat on the wall, or on the new paper?
Posted : 27/01/2017 1:12 pm
I wouldn't use a blade, spray it with lots of clean water, peel back to decent paper and then tear the bad stuff off. A feathered, teared edge will paste down far flatter than a cut edge.
If you're going to paint it, do the same with your patch pieces - just tear to roughly the right shape, absolutely saturate with adhesive and pack it down with the edge of a clean brush.
Posted : 27/01/2017 1:16 pm
Undercoat on the wall to stop stain potentially coming through. Straight edge cut as far neater and sticks perfectly well.
Posted : 27/01/2017 2:14 pm
Thanks everyone!
Posted : 27/01/2017 5:31 pm
I'd cut the rubbish paper away then put the patching paper overlapping over the top. Then with a sharp blade cut through old and new,chuck the edges you've cut off away, and voila.... a seamless patch.
Posted : 27/01/2017 6:49 pm
 teef
Do it properly - strip the paper off the ceiling and both walls and then re-paper. Anything else will be a bodge job and will always look like it. You may of course be happy with a bodge job.
Posted : 27/01/2017 7:35 pm
teef - Member
Posted : 27/01/2017 7:46 pm
teef - Member
Do it properly
Whoa, hang on there just a moment. How good is your Nan's eyesight and what sort of inheritance are you looking at? A bodge may be plenty good enough 🙂
Posted : 27/01/2017 8:10 pm
Strip the ceiling and walls?
Wood chip?
It will need nuking from orbit, you know?
Posted : 27/01/2017 8:15 pm
