My daughters confirmed with Covid meaning my son-in-law has to self isolate so I'm doing some work for him next week. I have to go to approximately 10 addresses in areas I'm not familiar with. My question then is this, are there any free Android navigation apps that I can input all the addresses and it will guide me from one address to the other? If not then I'll use google but I'll have to get to one address before inputting the next.
Thanks, Naffa
You can add stops on Google maps. You just need to add them in the right order. It'll then navigate you between all of them
I use Waze. It works just fine for me.
Yeah, Google maps lets you do it. I don't know if there's a limit.
If you put in a destination, you'll then get 3 dots top right. Tap these and choose "add stop".
If you don't get them in the right order you can drag them up and down the list.
Have a look at Delm8
Yeah, Google maps lets you do it. I don’t know if there’s a limit.
Yeah, there is. 10 including the start point.
You can put all the destinations in, in any order, then slide them up or down to get the most efficient route
YOu have there the travelling salesman problem which I believe is actually incredibly difficult to compute
https://en.wikipedia.org/wiki/Travelling_salesman_problem
If adding them as stops doesn't work, try putting them all in Google maps, save them as starred, or favourites, or whatever. Have a look at where they all are in relation to each other, and work out your own little route. Get to the first one, then you can use the voice assistant to ask Google to navigate you to the next one.
