Affinity Designer -...
[Closed] Affinity Designer - EPS Export Problem
Hello All
I have a graphic I have done (bike decals) on Affinity Designer. The image has a transparent background. I need to export it as an EPS file to give to the printers. Everything looks fine and the export runs smoothly. However, when I open the EPS file on its own the background is white? No matter which way I do it when I reopen the EPS file the background no longer shows up transparent.
Has anyone any idea what I might be doing wrong? Note I am by no means a professional in this field.
Is there another vector format file I could try that is widely accepted by printers?
Posted : 27/09/2020 11:55 pm
Don't know anything about affinity, I'd imagine it should export a transparent eps, it is possible, could just be the program you are using to view the eps and it can't display/see the transparency? (you're bringing back memories of quark 4 and clipping paths here! 😆 )
But anyway, just send the printer a pdf That'll keep the vector data.
Posted : 28/09/2020 12:38 am
Thanks Seosamh77. I thought that might be the case that the viewer was the issue.
I tried a pdf, same issue.
I do seem to have managed it with PNG however....... will the printer kill me?
Posted : 28/09/2020 12:56 am
aye, png is raster not vector, it's also won't do cmyk. So no use.
What are you viewing the pdf/eps in?
Posted : 28/09/2020 1:03 am
Ok thanks. Sent the printers a PDF and asked them to check for background transparency. It's a minefield.
Posted : 28/09/2020 12:47 pm
a vector graphic doesn't need a transparent background as it will, by default, have no background. However the default background colour for a lot of progs & PDF viewers etc is white so a graphic will look the same whether it has no background, a transparent background or indeed a solid white one. It's probably fine, but best if someone who knows what they're doing can check it!!
Posted : 28/09/2020 12:58 pm
andykirk
Ok thanks. Sent the printers a PDF and asked them to check for background transparency. It’s a minefield.
I'd guess it'll be fine. Like I say it's probably just what ever program you are using to view the exported file that's showing it up as a white background. The printers will let you know.
If it's just standard printing, it'll not print white anyhow. There's no white in CMYK. 😆
Posted : 28/09/2020 1:14 pm
