Advice Needed - Ope...
[Closed] Advice Needed - Open Gas Fire & Draughts
2 Users
Having moved house recently my new house has an open gas fire in the living room, coal effect with a marble hearth and back plate finished with a wooden surround.
With the cold weather over Christmas I has noticed that the fire lets in quite a lot of cold air when not used. The metal parts of the fire are freezing cold to the touch
So after turning of the gas I have stuffed paper in the fire flue outlet holes, it reduced the draught. Or so I though...
The draught then emitted from the seal of the fire surround and marble back plate thorough a 3mm gap, taped this...
Now the cold air is now pouring out of the 1mm gap between the wooden frame and wall.
Am I right in thinking that there is something seriously wrong with the fires installation and I need to call an expert before I consider using the fire?
Posted : 05/01/2012 9:29 pm
Must say that's interesting, our fire draws all the warm air from our room, to the point where I can put a 4ft sq x 1/2 inch polystyrene sheet to the front of it and it won't move lol.
Posted : 05/01/2012 9:39 pm
coffeeking
...our fire draws all the warm air from our room
Thats what I though would happen, even what not in use the warm air would be drawn out through the fire, my concern is if cold air gets in then fumes will
Posted : 05/01/2012 9:55 pm
