Adjusting photo tim...
[Closed] Adjusting photo time stamps on Mac?
Holiday pics from 3 cameras, only 1 camera had the correct date/time (one of the other is out by months, the other by a couple hours).
Is there an easy way to correct this on a Mac, without paying for an app? I don't want to use iPhoto, and would like to correct the dates before importing to Lightroom (plus I don't think adjusting the capture time in LR changes the EXIF data?)
Ta,
Duane.
Posted : 09/01/2015 7:21 pm
I think you can make those changes in Lightroom.
Edit [url= http://help.adobe.com/en_US/lightroom/using/WS57264460-DC72-4a1f-A665-1E90907A9FFD.html ]here you go[/url].
Posted : 09/01/2015 7:39 pm
Shame you don't want to use iPhoto, that would do it easily
Posted : 09/01/2015 7:42 pm
Exiftool is probably capable of doing it, depending on your command line skills, I only sussed out how to use it examine the EXIF data and then batch rename all the images in a folder to names based on the date and time the image was taken. But it's capable of writing EXIF data too.
http://www.sno.phy.queensu.ca/~phil/exiftool/
Posted : 09/01/2015 8:00 pm
Changing it in Lightroom doesn't change the actual photo EXIF data does it, just the time within LR?
Importing to iPhoto you have to create a library etc right?
Posted : 09/01/2015 8:02 pm
Anyone? ๐Ÿ™‚
Posted : 09/01/2015 9:30 pm
Picasa will do it... it's quite good in this regard, you can set photos to a specific time or adjust lots of photos by a certain amount. I always use it when I inevitably change time zones on one camera but not the other on holiday...
Posted : 09/01/2015 9:34 pm
Had a quick Google EXIF tool can shift the date/times, syntax is >>
exiftool "-DateTimeOriginal+=Y:M:D h:m:s" filename.jpg
To shift by 5 hours and 30 mins it would be >>
exiftool "-DateTimeOriginal+=0:0:0 5:30:0" filename.jpg
A negative shift by one day would be >>
exiftool "-DateTimeOriginal-=0:1:0 0:0:0" filename.jpg
Posted : 09/01/2015 9:56 pm
