A possibly stupid p...
[Closed] A possibly stupid plumbing / washing machine q
[#623401]
We are about to get our garage knocked down and moved. Our washing machine is currently in the garage and will go back in the garage when it's finished. Can we temporarily plumb it in to where the sink was in the downstairs toilet (also about to be redone) while they're doing the garage so we're not without a washing machine?
Posted : 11/06/2009 9:28 am
yes.
you need a washing machine fller tap on the cold water feed - easy compression or push fit - (assuming single feed) and you can connect the WM waste to the old basin waste - although you may need to elevate it.
Posted : 11/06/2009 9:32 am
Not forgetting that the water in the trap in the sink waste is the barrier between you and the bad smells so you might want to leave most of that intact or cap it off.
Posted : 11/06/2009 9:34 am
Marvellous, thank you 🙂 Much better than 6 weeks of laundrette trips!
compression fitting
pushfit
Posted : 11/06/2009 9:35 am
Do you want to come and do it for us stoner? 🙂
Posted : 11/06/2009 9:50 am
'you need a washing machine fller tap on the cold water feed - easy compression or push fit - (assuming single feed) and you can connect the WM waste to the old basin waste - although you may need to elevate it'
also worth putting a jubilee clip on the connection between the waste pipe and the basin.
Posted : 11/06/2009 9:52 am
You may need a hot water feed too?
Jubilee clip may be needed, depends on what fitting is there at the moment. I'm running mine straight into the waste out at the moment, no p-trap or anything. Crazy!
Posted : 11/06/2009 9:56 am
I *think* we only need a cold water feed, fairly sure that's all we've got in the garage. I will investigate later.
Posted : 11/06/2009 10:04 am
most/some washing machines heat water themselves, it tends to be older ones that need both feeds.
Posted : 11/06/2009 10:09 am
Mrsflash. Now that your plumbing is sorted would you be so kind as to judge the Knobbly Knees contest?
[url] http://www.singletrackworld.com/forum/topic/singletrack-knobbly-knees-contest [/url]
Posted : 11/06/2009 10:20 am
I shall be right there Mr Spider 🙂
Posted : 11/06/2009 10:23 am
Jolly good. I'd go for the thin ones with all the cuts.
Posted : 11/06/2009 10:25 am
that was pretty much all of them!
Posted : 11/06/2009 10:26 am
You don't even need to do any plumbing or turn the water off. B&Q sell a washingmachine/dishwasher tap that screws onto an existing water pipe. As you screw it on, it punctures the pipe to draw the feed. I've used them a couple of times and they are brilliant, you have an extra tap in seconds and they never leak. With the waste, just zip-tie the waste pipe to a sink tap so the waste just pumps into the sink bowl- you don't need to go replacing pipes etc.
Posted : 11/06/2009 11:56 am
