A bit of HTML help ...
[Closed] A bit of HTML help please
I have a simple webpage I am setting up.
http://nnolscotland.blogspot.com/2018/10/the-national-network-for-outdoor.html
The list of organisations halfway through - if I have them as text, there are two neat columns (which is what I want). As soon as I add a hyperlink to the text, it reverts to two columns.
What gives...?
Posted : 29/10/2018 11:36 am
Someone much clever than me will be along shortly, but I've used the "pre" tag to preserve text I have already formatted (this is only for simply HTML email signatures though!)
https://www.tutorialspoint.com/html/html_pre_tag.htm
Posted : 29/10/2018 11:41 am
You have two columns and then it changes to two columns?ย  โ“
It there CSS applying unwanted formatting to <A> tags?
Posted : 29/10/2018 11:52 am
your bottom column, the second "para-50" div is outside the the "multiple-para" div, both para-50 divs need to be with in that div. (I'm assuming you want 2 columns). if you right click(on chrome) goto inspect, you can move the div to test what I mean.
Posted : 29/10/2018 11:54 am
cheers sesomah - that has solved it.
For some reason when I added a link in, it moved one of the div...
Posted : 29/10/2018 12:24 pm
Semantically a list should be < ul > < li > item 1 < /li >ย  < li > item 2 < /li > </ ul >(if unordered, use ol instead if the the order is important). At the moment you are using line breaks to simulate a list.
Seeย  https://www.w3schools.com/html/html_lists.asp
You also appear to be using line breaks to simulate paragraphs.
Posted : 29/10/2018 12:33 pm
It is because most is auto generated by Blogger - I haven't coded from scratch....
Posted : 29/10/2018 12:58 pm
no worries glad to help. Yeah, can see you've been using something to edit it, just a quirk of that(along with many others obv, not within my remit to teach html here though!ย ๐Ÿ˜† ).
Posted : 29/10/2018 1:03 pm
