6 sheet and 48 shee...
[Closed] 6 sheet and 48 sheet poster, final output res?
2 Users
Any graphic designers kicking about?
As the title says, what final output resolution would you work to for a 6 sheet and 48 sheet poster? Never had to do these as of yet and i've only been supplied with page dimensions, not resolution. Should i just work to 72 dpi at these sizes? maybe 200dpi for the 6 sheet?
And also, indesign and illy don't go to 6096mm, is the best bet just work to to 50% size at double the output res?
Cheers for any input.
Posted : 17/08/2011 10:03 am
I've never done anything [i]that[/i] big, but did some big display materials recently in indd at 1/4 size, with images at 200dpi and outputted as high quality print PDF. The printer did the rest.
Was expecting it to be a bit more complicated but it wasn't. Give whoever's printing it a buzz and they'll tell you exactly how they want it.
Posted : 17/08/2011 10:27 am
Aye, interweb points to that to, seems it's very much dependent on the printer. I'll get in contact with them. ta.
Posted : 17/08/2011 10:39 am
